Author Topic: Speedometer Cable Removal  (Read 2901 times)
jmk
« on: February 11, 2008, 01:28:12 PM »
I've got a '72 CB750 My speedometer cable recently broke and the flathead screw on the front wheel to remove it was completely stripped.  I've tried to drill it out (after trying everything I knew how to get the screw out..I swear!  Who wants to re-tap a hole?) but the cable still will not pull out.
My questions is, is this the only screw to remove, or is there something else I have to do?  If it is the only screw I think I maybe just need to drill a little more, maybe deeper and wider to make sure I got the whole screw.
Any help is appreciated, thanks,
Jon-Marc
Offline Bob Wessner
  • "Carbs Suck!"
Re: Speedometer Cable Removal
« Reply #1 on: February 11, 2008, 02:21:51 PM »
It's the only screw you need to remove to be able to pull the cable end out. I don't know what it is, but these are hard to remove even after being in only a short time and no overtightening.
Offline Johnie
« Reply #2 on: February 11, 2008, 03:18:25 PM »
JMH...I had the same thing as the previous owner must have torqued mine in real tight.  I ended up even breaking an easy-out off trying to get mine out.  What ended up working for me was this...I took a small circular cutter on my Dremel and made a cut in the screw head.  I then took an impact wrench and it came out with the first hit.  Good luck with it...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline CBJoe
« Reply #3 on: February 11, 2008, 03:46:19 PM »
I feel your pain >:( .... I ended up having to remove the front wheel and axle on my CB650 so that i could simply replace it with the speedo from my parts bike.  I've still got the busted one hanging above my door as a reminder.
At least i'm not the only one... comfort in numbers right ;D
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline blackhog02
« Reply #4 on: February 11, 2008, 04:43:13 PM »
Dito what Johnie said.  Drimil tool with a cut wheel to make a slot and then an impact wrench on two of my bikes.
