slight hijack.......sam where did you get those 4-4 megaphones and were they very expensive?
Yes, they are expensive to build, We are about $25,000 out of pocket. You having to buy from this God forsaken place will probable end up spending more unless you are able to do a lot of the work yourself.
I have a mate in NZ that is building one (Andynzl) and I sent him loads of pics of where the brackets go, perhaps he could send them to you.
Now to answer Fuzzybutt. They came from the same place Swarpricks.
The down pipes are formed spot on but the megaphones came straight and were a nightmare to form to fit. God only knows how you are going to do it if yours have some type of baffle. I only hope the baffle don't go to far down the megga.
Good luck with the build, if you need any further info just yell.
Sam.
