Author Topic: Front brake caliper piston removal.  (Read 2403 times)
Offline crazypj
  • I'm brill, me
« on: February 17, 2008, 09:46:32 AM »
Hi Folks,
I found a new way to possibly hurt myself, it was so easy and fun I had to share ;D  ;D
 1970's Honda's all used similar caliper so it may work for someone else.
Didn't want to do the usual beating/drilling/grease gun etc. so though of something new.
HEAT
 Got hold of a long 10x1.25mm bolt and nut, copper washer and spacer.
 Sealed up caliper and started warming things up. Old fluid started to get hot and caused pressure inside
 I knew it was going to work when the pad moved.  ;)
 I would say though, wear long sleeves, safety glasses  and do it outside in open air.
 DON'T POINT IT AT ANYTHING IMPORTANT, piston comes out real fast
 Its probably no more dangerous than using compressed air to remove pistons (except for boiling brake fluid  ::))
 Couple of pics.
You can imagine how bad the pad was stuck
PJ
« Last Edit: February 17, 2008, 09:50:45 AM by crazypj »
Bob550four
Re: Front brake caliper piston removal.
« Reply #1 on: February 17, 2008, 10:21:11 AM »
I wouldnt be comfortable doing that myself.  but I got mine to move by using my master cylinder, a bunch more fluid and just kept pumping.  piston casually pops out and you can control it fairly well.
no messy grease to clean up, no boiling fluid to burn you, no real risk of injury.
« Reply #2 on: February 17, 2008, 10:53:03 AM »
I tried all the usual ways and nothing worked. The heat did the trick, just don't stand in front of it.
Offline crazypj
  • I'm brill, me
« Reply #3 on: February 17, 2008, 06:16:51 PM »
 I couldn't use your method as the master cylinder was full of jelly.
PJ
Offline MikeD718
« Reply #4 on: February 18, 2008, 06:14:26 AM »
i capped the brake line port, and used an airchuck with about 100psi through the bleeder port to shoot my piston out.
'76 CB750F
'76 CB550k
'66 CL160
« Reply #5 on: February 18, 2008, 08:19:40 AM »
I actually did the same thing but we used 200 PSI shop air directly plumbed to the Caliper - no dice. Once I put the torch to it the sound of an M80 blast filled the shop and the piston disappeared somewhere. I gave the unit to my friend who shipped it to his rebuilder in Cali and they fitted a SS piston and whatever else it needed.  If you use heat do not stand in front of it!!!!!!
Offline crazypj
  • I'm brill, me
« Reply #6 on: February 18, 2008, 10:50:21 PM »
It wasn't going anywhere with the 125psi I had available  ;D ;)
PJ
kta
« Reply #7 on: February 18, 2008, 10:54:41 PM »
This is a great idea. I have struggled a few times with stuck pistons and usually end up swapping out master cylinders to get a good one. Great tip!
Offline City Boy
« Reply #8 on: February 19, 2008, 07:35:38 AM »
I had occasion to take apart a 900F caliper the other day.Ihave a spare MC and some old brake lines so I filled the  system with water,half assed bleed and bingo,out came the pistons.Easy cleanup,no wasted brake fluid,no injury hazard!
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
« Reply #9 on: February 19, 2008, 07:48:06 AM »
I agree that you go the most conservative route first. There are some like mine that would take extreme measures to remove. If 200 PSI piped directly into the caliper will not move a piston, it is stuck. With the heat we are expanding the caliper metal and probably causing an explosion at the same time. It is your last option and should be done carefully.
That piston sailed over some railcars and was never seen again.
Offline crazypj
  • I'm brill, me
« Reply #10 on: February 19, 2008, 07:56:56 AM »
Thats funny (and potentially serious) but, don't care who you are, thats funny
 ;D ;D
PJ
Offline goon 1492
  • Sucka Repellant
« Reply #11 on: February 19, 2008, 09:34:34 AM »
SWEEEET ;D ;D ;D that almost sounds like it could be fun, mount up four calipers to a stand, setup some targets and blamo- high caliper 8) target practice, only at the local gun range though for saftey purposes 8)
Offline Prospect
« Reply #12 on: January 17, 2010, 05:16:31 PM »
Hi Folks,
HEAT
 Couple of pics.
PJ
I guess both the bleed valve and brake line holes have to be sealed up for this to work?
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline crazypj
  • I'm brill, me
« Reply #13 on: January 17, 2010, 09:01:11 PM »
leave bleeder locked down, seal up fluid line, heat til it 'explodes'  :D  8)
 As I said, its stupid and dangerous, that's what makes it fun  ::)
PJ
Offline Prospect
« Reply #14 on: January 18, 2010, 08:16:59 AM »
Thanks crazypj.  Worked like a charm.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
