Hey guys, thanks for the feedback. Picked up the bike this weekend. Looks in much better shape in person. Still haven't gotten it started yet, waiting for keys through mail from owner.
I checked the VIN and Engine number but can't match them up in the model guide.
VIN: CB750-2559513
Engine: CB750E2-448793
There's also a black pastic cover/container under the tank on the left side that says CB750F on it.
As some of you mentioned, these bikes are mix and matched parts by now, but any help identifying would be great. Thanks.
that black plastic cover/container is the airbox, they all say cb750f (at least all the 72-76 ones I have seen).
the 1976 frame numbers start at Frame #: CB750-2540001. Your frame number is 2559513 , which indicates it is well into the 76 production. the 76 engine numbers start at CB750E-2428762 and your number is 2448793.
That blue is not a factory color or paint job (I should know I own a factory 75 blue bike in it's original paint). The sidecover is pretty close to the candy antareis red but is a little dark and the paint looks oxidized. If you decide to paint it the factory color in the factory method you will need to spray a silver base and then a red candy paint over it. Then apply the decals and clear. Decals for the 73-76 are commonly available (small stripe variations between years). You could also get a basecoat clear coat metallic that is close and most people wont know the difference.
Juging from the pics it looks like most of the factory stuff is there. Off hand the chain guard, rear backrest, and exhaust are not original to the bike. The bolt holding in your idiot light cluster looks like a home depot special and not the chrome bolts the factory used, check your bike for the correct hardware throughout chances are you will find more unoriginal fastners. Check for any torn up screwheads on the engine, you'll wanna replace those with Stainless Steel allen head screws.
The important thing is to just have fun with the bike, k6's aren't worth a whole lot so pretty much the sky is the limit on what you wanna do.
