Author Topic: Rim swap... need some help  (Read 876 times)
mdl91881
« on: February 19, 2008, 04:17:29 PM »
The bike is a 78f with comstar rims rim now.
I was able to find (from another board member) a 76 F spoked rim :)
My question is, will this rim bolt right up using the sprocket, brakes, hardware, ect from the comstar that I already have?  Or will I need to use all the goods from the spoked rim.
I check the diagrams/part numbers on bike bandit and the only part that seems to be crossing over is the brake rotor :(
Im sure someone has done this swap before. Im just trying to figure out if im getting myself into a bigger project/expense then id planed.
Thanks in advance!
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
Re: Rim swap... need some help
« Reply #1 on: February 19, 2008, 04:47:23 PM »
I believe the swing arms are different lengths. Did you get the axle as well?
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
mdl91881
« Reply #2 on: February 19, 2008, 04:52:43 PM »
Havent got anything yet.  Trying to figure out what I will need an if it woth the effort
