Author Topic: '75 CB400F Parts Cleaning  (Read 1839 times)
broken
« on: August 05, 2005, 09:02:28 AM »
Soon to get a 1975 CB400F back from a shop ( bought it from a fella that had it stored improperly for 10 years ) I need to clean it up big time, I'm completely green as far as this stuff goes so I was hoping for some tips. I've read a lot of info regarding how to clean chrome, aluminum and the like in these forums however I don't want to mix up what parts should be cleaned in what way, so, I was hoping someone would be nice enough to break down the major parts and basic cleaning technique for that part or set of parts. Not looking for the complete parts list or something like that but just the majors and what they're made of, I can tell chrome apart, but what's obvious to all you fellas as far as materials I'm not quite confident I'll be able to differentiate as this is my first bike. For example,
Spokes / Rims ( Aluminum? ) - clean w/ scotch bright and spray with ant-rusting agent or anodizing agent
Pipes ( Chrome ) - clean w/ vinigar or other rust remover, polish, clean heavy rust w/ sandpaper?
Bars ...
Fenders ...
Seat ...
Kick Stand / Center Stand ...
Swing Arm ...
Frame ...
Tank ( how hard is it to bump out dents? ) ...
Thanks alot, can't wait to get on the road with this puppy.
bro`ken
« Last Edit: December 27, 2006, 04:11:29 AM by Glenn Stauffer »
Offline CB750R
  • 77 CB750F
Re: '75 CB400F Parts Cleaning
« Reply #1 on: August 05, 2005, 10:32:40 AM »
Rims and spokes are likely chrome, As for what is what pull out the old magnet, if its chromed, chances are its also steel, and if its aluminum the magnet wont  stick.  Highy alkaline degreasers will etch aluminum, which is bad, so stick to stuff made for general degreasing, and products that are safe for rubber.  Also nothing too crazy on the paint in terms of chemicals either, or your going to end up stripping off old paint.
  Look up Caswell plating, they have a ton of products made to polish aluminum, adn chrome and such, I purchased thier aluminum polish kit and was very happy.
Oh ya and elbow grease mixed with a few beers, is usually the most effective cleaning product!!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: August 05, 2005, 11:53:28 AM »
Avoid the temptation to use a pressure washer at any stage, it has a habit of depositing water in places you don't want it.
bike54
« Reply #3 on: August 05, 2005, 04:31:11 PM »
hi all
im cleaning my old girl as well one thing you will find once you start about twice the amount of things will need cleaning than what you thought because clean bits make outher bits look tatty
main thing needed patiance and elbow grease and a plan of action i have started at the front wheel and am going back 2 weeks and just got to the engine clean it once and clean it right
bike54
Offline kghost
« Reply #4 on: August 05, 2005, 07:23:45 PM »
Bike54,
Yup, Many restorations started by making a clean spot.
One clean spot and your committed.
Stranger in a strange land
