Author Topic: 750A Hondamatic oil pump questions  (Read 1209 times)
Offline JLeather
« on: March 03, 2008, 04:45:20 AM »
For anyone who is familiar with the 750A, does it use a standard CB750K/F oil pump?  Since it has to oil not only the engine, but also has to supply and feed the torque converter, I'd expect the demand to be much higher than a normal CB750.
Part 2, does anyone know where I can get a 750 oil pump blueprinted?  Does anyone sell an aftermarket 750 oil pump?
Re: 750A Hondamatic oil pump questions
« Reply #1 on: March 03, 2008, 05:13:31 AM »
Totaly different pump even in a different place, part number 15100-393-000 try all the usual places and i very much doubt antbody but Honda made them
Offline JLeather
« Reply #2 on: March 03, 2008, 06:09:35 AM »
Is it possible to have one rebuilt/improved?
« Reply #3 on: March 03, 2008, 07:12:07 AM »
Depends what is worn out, The end clearance can be re-machined but the lobes and diametrical clearance is another matter unless you can find a different pump internals that fit. it would probably be easier to scour the wreckers for another bike. It appears to be under the LH engine cover
