Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
I wanted to report the results of my purchase and use of Safest Rust Remover. It's about $132 per 5 gallon bucket (includes shipping). It's basically the same chemical as Rusteco except half the price. It's advertised in Hemmings Motor News and on the web. The website is www.safestrustremover.com.It's non-toxic and biodegradeable. No harmful fumes. Doesn't damage paint or skin. And it doesn'tdissolve metal, so no need to Kreem or coat the tank because the remover doesn't eat metal.IF the rust is so bad that you have pinholes, you will probably need to coat but if your tank isrelatively good shape with only surface rust then you're in luck.I drained the gas and removed the gas tank from my 1978 CB750K. The inside of the tank was rusty and I was toldby the original owner that is was previously coated, but he didn't know what was actually done.I removed the petcock and filled the tank with warm water and simple green. I rinsed the tank and plugged ita foam ear plug and duct tape.I filled up the tank with the rust remover. I put the gas cap back on and let it sit on my bench.By day 2, the tank coating was peeling off like slime inside an aquarium. The gas cap chain was rust free and I could start to see "new" metal on the tank surface.By day three, the entire tank looked new and the old coating was floating in pieces likeseaweed.I drained the tank and rinsed with warm water to remove the pieces of coating.I filled the tank back up with the rust remover and let it sit overnight. I drained the remover and sucked out the excess with a wet vac.I installed the petcock and put 2 gallons of gas in. I picked up the tankand sloshed the gas to coat the entire tank.I reinstalled the tank and put a Fram gas filter in between the petcock and carb line.I poured in a half a bottle of water remover and filled the tank at the gas station.The tank looks brand-new and not a spot of rust. No need to coat with Creem orsimilar product as the gas will keep it rust-free as long as I keep it topped off.This is the way to go if you have rust in your tank. I highly recommend it. I'm not a salesman or dealer, just a happy SOHC owner with a nice gas tank.
muric acid, works wonders, and doesnt eat paint... be careful not to leave it too long in a really rusty tank and use baking soda to neutralize when done. caution will eat skin...
pretty nifty ideas involving a jar of molasses on here for cleaning your tank if you do a search on it.....they say it works.
