Author Topic: What are the dimensions of a CB750?  (Read 1417 times)
Offline JLeather
« on: March 06, 2008, 04:29:01 AM »
I'm at work and the shipping place needs the packing size of a CB750.  If I take the mirrors off, how long/wide/tall is a CB750 (it's a K0, not an F or anything)?  Anyone know, or is in a position to measure for me?  Thanks guys.
Offline Bob Wessner
  • "Carbs Suck!"
Re: What are the dimensions of a CB750?
« Reply #1 on: March 06, 2008, 05:27:36 AM »
I'll be heading out to the garage in a little while to check how much two stroke fuel mix I still have for the snowblower :-\ and can report back if you like.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: March 06, 2008, 05:45:56 AM »
Better yet, remembered this is in the Shop Manual. Hope you can read it. You should be able to save an print to a legible image.
Offline Jonesy
  • Shop Rat
« Reply #3 on: March 06, 2008, 05:46:40 AM »
In the front of the shop manual it gives all the major dimensions of the motorcycle. (Too bad I'm not at home where I have access to the PDF I have, or I could post it right now.) :(
EDIT- OK, Bob beat me to it....
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #4 on: March 06, 2008, 05:48:51 AM »
According to my Honda shop manual, the measurements for the CB750 are as follows:
Height: From ground to top of brake master cylinder, 44.1 inches.
Width: End of handlebar to End of handlebar, 34.8 inches
Length: From front of tire to end of fender/taillight, 85 inches
Hope this helps!
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline JLeather
« Reply #5 on: March 06, 2008, 06:00:24 AM »
Thanks guys, that's exactly what I was looking for.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: March 06, 2008, 06:07:38 AM »
Oh, and Honda manual lists the curb weight as 517 lbs.
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
« Reply #7 on: March 06, 2008, 10:52:25 AM »
Just take care to have some space for padding and cushion.
Make sure the crater knows what he is doing...(hint,  watch the center stand)
Jona
Found real friends here !!!
