Author Topic: Can i use a 750K2-K5 carb on a 78 750f2?  (Read 726 times)
Offline Marco83
    • *My PhoTo AlbUm*
« on: March 08, 2008, 05:42:43 am »
Hi all,
Can i use a 750K2-K5 carb on a 78 750f2??
Thank
marco
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: Can i use a 750K2-K5 carb on a 78 750f2?
« Reply #1 on: March 08, 2008, 07:12:55 am »
You can, but to swap carbs, you also need to swap the throttle cables out for ones off of a 75f, or 70-76k and the carb mounting rubbers for the earlier carbs.  You'll also need to slightly reroute the fuel line, and turn the petcock on the tank 45 degrees, if you have the petcock where the outlet points out the back. Otherwise the fuel line will interefere with the earlier carbs choke lever, and you wont be able to fully close the choke. If you have the petcock where the outlets are on the bottom, then you can leave it as is. You may have to rejet as well...
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline cafe750
« Reply #2 on: March 08, 2008, 07:23:08 am »
Oh, and if you can get a hold of K6 carbs, it'll make your life easier because the idle screw was moved to the right side of the rack. On the K1 ~ K5 carbs, it is on the left, and its a pain in the butt to get to  with the F bikes petcock in the way.
Roy, Washington
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #3 on: March 08, 2008, 10:54:52 am »
Thank for the reply. Will it be any power(HP) loss if i use K early K carb on it?
« Reply #4 on: March 08, 2008, 12:45:39 pm »
It might seam so, as the earlier carbs do not have an accelerator pump.  However, the carb throat diameter is the same.  So, no difference at WOT.
