Author Topic: need help with brake piston seal  (Read 846 times)
Offline KeithB
« on: March 08, 2008, 09:30:07 AM »
I am trying to confirm the correct part number for the piston seal of the front calliper for a CB750 1978 K8
Service Honda shows 2 numbers for the same part.
45215-533-004
              -043
The original part is about 50mm outside diameter.
Can anyone confirm the correct #?
Thanks!
Nanahan Man
Re: need help with brake piston seal
« Reply #1 on: March 08, 2008, 12:59:51 PM »
If its only the last number changed its usually either a market area change or a manufacturer alteration
Offline KeithB
« Reply #2 on: March 09, 2008, 05:19:51 AM »
Thanks for the info..:)
Nanahan Man
