Author Topic: Coil Choices  (Read 1660 times)
revjim
Coil Choices
« on: March 08, 2008, 12:52:46 PM »
I have a 750sohc 74 engine.  I have coils that I think would run a cb750  they are these   http://i252.photobucket.com/albums/hh19/revjimmc/DSC00873.jpg  http://i252.photobucket.com/albums/hh19/revjimmc/DSC00872.jpg
will these work for my engine?
Offline mystic_1
  • 1970 CB750K
Re: Coil Choices
« Reply #1 on: March 08, 2008, 01:01:52 PM »
What are they off of?
mystic_1
- John Augustus Shedd
revjim
Re: Coil Choices
« Reply #2 on: March 08, 2008, 01:04:07 PM »
they are off of a cb650 I believe...maybe a cb550.
c15racer
Re: Coil Choices
« Reply #3 on: March 08, 2008, 02:11:15 PM »
forgive me if im being really stupid but how do you know if a coils suitable for the job?
Ive found a few twin output coils to replace mine but im really unsure on how i know if theyre ok?
ive just found the ones on this page about half way down......
http://www.norbsa02.freeuk.com/goffyelectrex.htm
12V coil with 2 outputs for twin cylinder machines, modern or classic. 3 Ohm impedance For points or electronic ignition.
The moulded in HT leads are 560MM (22 inches) long.
Body 70MM (with mountings 97MM) x 43MM
  These give the fattest blue spark you've ever seen £27.50 ea.
any good to replace my originals?
edit: ill get the new points and condensors in first and see what happens
« Last Edit: March 08, 2008, 02:31:13 PM by c15racer »
Offline CBJoe
Re: Coil Choices
« Reply #4 on: March 08, 2008, 02:51:49 PM »
Those aren't from a CB650 unless the '79's were different from '80 and later.
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
222CT
Re: Coil Choices
« Reply #5 on: March 08, 2008, 03:02:07 PM »
hey man whats up??  yeah i think those will work.....take an ohmmeter and measure the ohms on the connectors.  if you have points 5 or 3 ohms will work...if you have EI ignition....you need 3 ohms....but if i am wrong i am sure someone will say so.  i have a dyna s ignition and coils from a honda cbr 929 that are 3 ohm,  and she never ran better.  i had stock coils with the dyna and was having weak spark problems.  but that is another thread.
222CT
Re: Coil Choices
« Reply #6 on: March 08, 2008, 03:06:44 PM »
come to think of it revjim....i looked more closely at your pictures....i think those coils are off a newer bike, those brackets are similar to the 3 ohm coils i got...i think they are 3 ohm, and will work with points or even better a EI ignition.   use those coils and upgrade later, but yeah i am pretty sure they will work.
Offline CBJoe
Re: Coil Choices
« Reply #7 on: March 08, 2008, 03:11:37 PM »
'65 CB77
'66 CM91 (C90'ish)
