Author Topic: Jetting  (Read 926 times)
Offline OldSkul
Jetting
« on: March 09, 2008, 10:03:11 AM »
  I was always curious why the main jets get increased to enrichen the mixture when adding headers air pods ect. Why is the air jet left alone and not decreased instead?
 Thanks for any explanations...
                                                Henry
Re: Jetting
« Reply #1 on: March 09, 2008, 10:15:58 AM »
Fuel jets are usually replaceable/ removable.  Air jets are usually drilled into the carb body.  Making a large hole smaller would be an interesting challenge in that the material is difficult, at best to weld and add metal, particularly inside a small tube.
Further, adding pods generally reduces the vacuum or "pull" on the fuel jets.  Getting them to flow as before by widening has a greater effect than narrowing the air jet.
Also, the main air jet usually feeds both the main and throttle valve jets. These two fuel suppliers may need to be adjusted separately to address mixture differences at certain throttle settings.
It may be interesting to note, that in the Honda shop manual pictures of the cb550 K3's PD carbs, they show screw in air jets.  I expect the pictures were taken of engineering development carbs where they fine tuned these carbs for optimum settings, then specified a drill size for production models.
« Last Edit: March 09, 2008, 10:21:54 AM by TwoTired »
Offline rachet
  • '77 CB750 F2
Re: Jetting
« Reply #2 on: March 09, 2008, 10:19:12 AM »
Good info TT, and well said.  I appreciate the info!
Rachet~
But I need Tacos!  I need them or I will explode!
Offline OldSkul
Re: Jetting
« Reply #3 on: March 11, 2008, 02:22:30 PM »
Thanks for that explanation. I was thinking in terms of the air flow being static. :)
(Very well said)
  Henry
