Author Topic: Will diffusers from HM300 pipes fit in HM341 pipes (CB750)??  (Read 1725 times)
Offline markb
  • When I finish my current project I might be a
« on: March 11, 2008, 11:22:36 AM »
I've got a decent set of HM341 pipes that I'd like to run on my K0 until I can afford to buy a set of new HM300's.  Anyone know if the K0 diffusers will fit the 341 pipes??  What differences are there in the pipes?
Thanks,
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline JLeather
Re: Will diffusers from HM300 pipes fit in HM341 pipes (CB750)??
« Reply #1 on: March 11, 2008, 11:46:45 AM »
Nope, the HM300 diffusers are larger (and so is the opening in the end of the pipe).  That's why they sound so cool.  The HM341s are a smaller diffuser and are quieter.
Offline 736cc
« Reply #2 on: March 11, 2008, 11:48:58 AM »
  If you are very brave and like to hop things-up, remove the 341 caps, get a loooong 3/8" drill bit and drill a bunch of holes inside the pipes. Leave the caps off or hacksaw them to open-up the tiny outlet. They will sound and breath like 300 pipes. And you will be officially a hack.
Offline markb
« Reply #3 on: March 11, 2008, 06:36:09 PM »
What if I run the 341's without the diffusers, would they breath about the same as the 300's with diffusers.  I'm wanting to run standard plugs and carb setup until I can get the real thing.
Offline Jonesy
  • Shop Rat
« Reply #4 on: March 11, 2008, 06:46:49 PM »
Removing the diffusers from HM341's might improve the sound a little, but the HEm341's have baffling welded in place inside. The HM300's were open expansion chambers with glass-packed tips- quite a difference in construction (and performance!).
« Reply #5 on: March 11, 2008, 07:07:22 PM »
I love my HM300's...............  ;D
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #6 on: March 11, 2008, 07:09:46 PM »
You can run the 341's without diffusers, and its loud, with a sound similar to the 300's, but much "tinnier". The 300's that I have replaced my diffuser-less 341's with, perform better, and have a much "tighter" sound, and thats with the 300's diffuser in. I too Love my HM300's... ;D . Hope this helps a bit...
« Last Edit: March 12, 2008, 05:39:19 AM by cafe750 »
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
« Reply #7 on: March 12, 2008, 05:25:45 AM »
+1  (and I also have HM341s - completely different sound)
I just replaced the baffles on the HM300s (well 2 of them at least) and wow what a difference in sound! Is this normal? Do new baffles really make that much difference? Should I replace the other 2!? Sounds much throatier now, love it! Of course I did change the pipes from the CB750K4 to the K2 but didnt think this should affect the sound......
good luck in getting the HM300s....
Cheers
Andy
Offline 736cc
« Reply #8 on: March 12, 2008, 08:24:21 AM »
  Remove the HM300 baffles and hacksaw-off the inboard-ends and chuck the cloth while you're at it. Replace the baffles (diffusers). Now we're making the perfect tone, something between HM300 w/ and w/o baffles.
Offline Jonesy
  • Shop Rat
« Reply #9 on: March 12, 2008, 06:33:13 PM »
I just installed brand-new HM-300's on my 750... Now I REALLY have spring fever!!!
Offline markb
« Reply #10 on: March 12, 2008, 07:24:00 PM »
Thanks for all the great replies.  Looks like I might have to bite the bullet and by the 300's.  It's the right thing to do.
Offline Jonesy
  • Shop Rat
« Reply #11 on: March 13, 2008, 03:07:04 PM »
I finally got to take mine for a very brief and chilly ride today, and I see what you mean. The 341's sound "tinny" as someone described, while the 300's sound sort of "nasal" (best word I can describe it with). I might try your approach...
« Reply #12 on: March 13, 2008, 03:23:06 PM »
Agree Jonesy! Im going to try and get some video of the HM300s this weekend.....and post it on here...my HM341/K4 bike is not re-assembled yet so comparison for me at least will have to wait.
« Reply #13 on: March 15, 2008, 01:00:14 PM »
Here is a movie I took yesterday after riding home...little bit of camchain noise that needs to be adjusted but you get the idea with the pipes when throttle is turned...sorry i was doing to myself so filming/throttle is a bit off....upper 2 baffles are new....
http://s141.photobucket.com/albums/r58/andy750/?action=view&current=P1090240.flv
cheers
Andy
