The carbs are the last thing to tune in the tune up sequence, unless you like doing work twice.
I don't remember your bike's history, but if a float valve is leaking and and making the bowls too full, it can make those sounds and black plugs, too.
Hope you didn't use 22MM for a float height on the 78's PD carbs.
