Author Topic: Is my caliper piston useable????  (Read 4466 times)
Offline 1975cb550
  • lovin' the old honda's
« on: March 12, 2008, 01:31:48 PM »
my caliper was frozen and then i got the piston out with a lil work. but it's somewhat pitted i don't know if it's still useable. here is a pic. its not to good quality but maybe it'll help.
1974 CB750k
1975 CB550k
1998 VTR 1000 Superhawk
Re: Is my caliper piston useable????
« Reply #1 on: March 12, 2008, 01:41:33 PM »
I'm not sure.  But, if you make the picture fuzzier, I'd say yes for sure.
Nice focus in the box of Kleenex though...
 ;D ;D ;D
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: March 12, 2008, 01:43:29 PM »
most digital cameras have a "macro" mode, it's icon is often a flower, that lets you take extreme close-ups with good focus.  Perhaps your camera has this feature?
mystic_1
- John Augustus Shedd
Offline fonz
  • Satan is my motor.
« Reply #3 on: March 12, 2008, 02:48:33 PM »
Where exactly is it pitted? If it's on the inside of the piston, or on the end, I'd say it's alright, provided it's not pitted to the point of almost being eaten through. If the pitting is on the sides, I wouldn't use it, as the sealing ability would be compromised.
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #4 on: March 12, 2008, 03:04:25 PM »
I recently tried re-using a piston that looked
very similar, it was not useable and had to be replaced.
Bikes parked out front mean good chicken-fried steak inside.
Offline 1975cb550
« Reply #5 on: March 12, 2008, 03:12:48 PM »
i think its the finish that screws the camera up. i'm not sure though. i think this pic is better
1974 CB750k
1975 CB550k
Offline fonz
« Reply #6 on: March 12, 2008, 03:19:11 PM »
Personally, I wouldn't put much effort into that piston.
Offline 1975cb550
« Reply #7 on: March 12, 2008, 03:31:20 PM »
where can i get a new piston? and how much am i looking at?
1974 CB750k
1975 CB550k
Offline fmctm1sw
« Reply #8 on: March 12, 2008, 03:37:19 PM »
I bought one of those phenolic pistons from a guy here.  Worked in my 350F...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fonz
« Reply #9 on: March 12, 2008, 03:38:24 PM »
Does bikebandit.com have them?
« Reply #10 on: March 12, 2008, 05:05:02 PM »
If money is tight, you can probably re-use that piston.  It won't leak, but there is some risk that the caliper seal won't retract it properly, and allow the fiction elements to drag.
PM Kevin Hunter  ( Kevin400F )  He sold me phenolic pistons that I intend to use on the next brake rebuild.
Offline Blueridgerunner
  • CB650 no longer, but do have an 87 GL1200
« Reply #11 on: March 12, 2008, 06:02:17 PM »
the last time I checked the phenolic pistons were available on eBay. Won't fit my 650 tho. Had to get mine from David Silver Spares in the UK  ::)
Said James "In my opinion,  there's nothing in this world, beats a '52 Vincent and a red headed girl"
Laissez les bons temps rouler
Offline hymodyne
« Reply #12 on: March 12, 2008, 06:09:47 PM »
I had a reused pitted piston ruin a trip to lake champlain. the last 150 miles of the trip, I my front caliper rubbed and built up heat... a new piston is well worth the money.
hym
Offline UnCrash
  • Pass
    • My Blog
« Reply #13 on: March 12, 2008, 06:14:10 PM »
My pistons looked like that on my 750 when I pulled them all apart for cleaning.
If it were me looking at that piston. I would try to clean it up and see how it worked before buying a new piston.  That's just me though.  I'm a cheapskate, and willing to try to clean and fix before purchasing.  This sacrifices time, if you have that in abundance.  If not just buy it.
If you do in fact have some time to put into it (probably only 3 hours) here's what I would do.  Take some 600 grit wet sanding paper, and clean up the piston and the piston chamber in the brake caliper. With the caliper dry (wipe it out with a paper towel) the piston should drop in and out relatively easily while being a snug fit.
Re-assemble, bleed the brakes till they're firm and responsive and determine if the piston retracts successfully when you let go of the brake.  Ride the bike down the driveway and see how it feels.  If successfull ride it around the block and see how it feels.  If you have any binding or brake dragging, you may need to replace the piston.  If all is good, ride her like hell.
Best o luck.  And please remember that's just what I would do (and have done with more than 2,500 miles of success) with my bike.
« Reply #14 on: March 12, 2008, 06:22:20 PM »
The way I look at it is if the pits traverse the seal then pitch it. If that is the case then the pits will carry brake fluid past the seal. OR you could try to fill the pits with something that is resistant to brake fluid and very carefully sand them down. If the second choice is appealing you need to decide whether you're going to use DOT3/4 or DOT5 to determine what you'll use to seal the pits. Epoxy or JB weld perhaps?? I DO NOT KNOW (my disclaimer). Some of the guys have tried this but I have no experience doing so. My last tear down determined my pits were not an issue since they did not traverse the seal. I then went with DOT5.
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: March 12, 2008, 06:44:15 PM »
To answer your question, "is it useable?".  Yes.
Is it ideal?, No.
tomswift
« Reply #16 on: March 12, 2008, 07:04:13 PM »
my vote is for reuse the piston... but read this carefully:
pull off the caliper and inspect behind the pad after 500-1000 miles. if it is wet with brake fluid, go straight to the ordering place and put yer money down
don't forget... clean out that indented space where the square-ring goes... especially the part you cannot see!!! Gotta use bent tools, I bent a coat hanger, then flattened out a scraping edge. I sell this fine tool on ebay for $75!! <joke>
Seriously, by cleaning out the seal seat you allow it to spread evenly around the caliper body, and then evenly against the piston. Your little pits may allow a miniscule amount of fluid to seep out, but you shouldn't see a "wet spot" unless there's something on the back of the piston I don't see.
Good luck!!
TS99
Offline 1975cb550
« Reply #17 on: March 12, 2008, 07:14:55 PM »
yea i can't see spending $80 bux on it. thank for all your input. Tomswift is your bike a cb550? year? it looks a lot like mine. rock on!
1974 CB750k
1975 CB550k
tomswift
« Reply #18 on: March 13, 2008, 05:32:47 AM »
Yes, it was a CB550K I bought and got back on the road looking good for $500 - it was the 3rd CB550 I have owned
I just pulled this photo up to post, I will replace it with the CB750F project I have started in about a month - yesterday I painted the frame
here is a "before" photo
and here is after...check out the funky blue chain
Offline bozo4onion
« Reply #19 on: March 13, 2008, 07:34:41 AM »
Yours looks just like mine. Crap. Just ordered one from honda parts direct. About $65. Thought a new seal would fix my leak. No such luck. Good luck.
Offline crazypj
  • I'm brill, me
« Reply #20 on: March 13, 2008, 07:57:32 AM »
hym
 A pitted piston WONT CAUSE BRAKES TO RUB.
 It may leak but it wont cause brakes to rub/drag.
 Bad adjustment or set up causes that problem.
Even if brakes drag, when pressure gets too high fluid returns to master cylinder
 See post about non-return valve for probable cause
http://forums.sohc4.net/index.php?topic=31966.0
PJ
Offline Gordon
  • 750K1, 550K2
« Reply #21 on: March 13, 2008, 08:33:17 AM »
So you're saying a rough, pitted, rusted surface on the piston can in no way cause extra drag against the piston seal, thus keeping the piston from fully retracting into the caliper?
I have to disagree.
Offline crazypj
  • I'm brill, me
« Reply #22 on: March 13, 2008, 08:59:53 AM »
I have to disagree.
Extra drag means the piston wont extend which will cause it to over-retract, at least until there is enough wear on pads to allow too much movement in lever and you have to pump up brakes to get them to work.
PJ
Offline Gordon
  • 750K1, 550K2
« Reply #23 on: March 13, 2008, 09:03:18 AM »
PJ
But the force applied by the rider, via the MC, to extend the piston inside the caliper is much greater than the force required/applied to retract the piston.
Offline mustangcar
« Reply #24 on: March 13, 2008, 09:52:04 AM »
should still be good.just wetsand the fk out of it,with 400 grit then 2000 grit so long as the pits don't scratch the seal,also wetsand the bore and if using an old brake pad the side of holding pad plate,
