Author Topic: Timing creep  (Read 1251 times)
upperlake04
Timing creep
« on: March 12, 2008, 04:36:42 PM »
  Early last summer I installed  $6.00  Daichii points on the 750F.  At about 1000 miles I again checked the advanced timing with a strobe and found the timing to be slightly advanced, not where I had set it and not noticeable to me when running.  I reset again between the advance marks with the strobe and 1000 miles later I checked and the same, slightly advanced. 4 times I did this.
  Is there a logical explanation?               Thanks, Dave
Re: Timing creep
« Reply #1 on: March 12, 2008, 04:43:08 PM »
Hi Dave, check for wear on the heel of the points, the part that rubs on the cam.
Sam. ;)
Re: Timing creep
« Reply #2 on: March 12, 2008, 05:39:34 PM »
Dave, the point gap does effect the timing. When I had points I had a problem getting 2-3 where I need them. I had the choice of elongating the slots or tweaking the points. Since it was minor, I tweaked the points. I think you points are probably the cause.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Timing creep
« Reply #3 on: March 12, 2008, 07:04:32 PM »
You sure the adjusting plate is synched down good and tight? Probably is, but thought I would ask.
