Author Topic: Keihin CR31 Carb settings  (Read 2422 times)
Offline lordmoonpie
    • Moonpie
« on: March 13, 2008, 05:52:11 AM »
Anyone used Keihin CR31 carbs on a CB750 engine - the pukka old ones with ticklers? I could do with a base setting for jets, needles etc if anyone knows what I should be using??
Thanks  ;D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Re: Keihin CR31 Carb settings
« Reply #1 on: March 13, 2008, 03:42:26 PM »
No.  :D :D :D :D :D :D :D :D :D but I know a guy who dose, will go find his name.
Sam. ;)
Offline JLeather
« Reply #2 on: March 13, 2008, 04:12:44 PM »
Did you happen to pick those up on eBay recently?
Offline Jim F
  • go baby go
« Reply #3 on: March 13, 2008, 04:14:15 PM »
Dont ask me..............Still waiting to here about what the air screws should be set at, what size pilots and where the clip needs to be (836 motor)
Would ask Sam but he only runs WFO
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #4 on: March 13, 2008, 04:30:53 PM »
Yes Jimmy, the ones that Simon is referring to are not the same as the ones we use.
His are the early ones that were used in 69/70s on the factory bikes, they were part of the race kit.
Sam. ;)
Offline lordmoonpie
    • Moonpie
« Reply #5 on: March 14, 2008, 05:21:17 AM »
No - didn't pick them up on ebay recently, had them for four or more years - not common little fuellers these so I got in well early for my build knowing they'd be needed at some point...
1994 Ducati 888 SP5
Offline Bodi
« Reply #6 on: March 14, 2008, 08:11:57 AM »
Ahh. Real man's carbs!
I worked on a 750 with them installed back in the 70's, electrical stuff. I don't know what else the guy had done to the motor, but it was very fast and had a wicked sound from the velocity stacks when at full wick. One definitely needed ether spray to get the damn thing going from cold, though. And a strong leg or well charged battery... the new series CR carbs with chokes are for sissies.
Offline lordmoonpie
    • Moonpie
« Reply #7 on: March 14, 2008, 01:19:13 PM »
Guess it'll be strong legs for me then - this is gonna run a self generating system so no batteries for me - woohoo! ;D
1994 Ducati 888 SP5
Offline Bodi
« Reply #8 on: March 15, 2008, 09:10:22 AM »
I've seen dirt track bikes with chokeless carbs started using a piece of cardboard with a hole (about 1/2") held over the velocity stack as a choke to get the engine going first thing out of the trailer if they have a starting roller or kickstart. Maybe something could be made to bridge all four - assuming velocity stacks. Without starting spray or some sort of choke, though... well, good luck!
