Author Topic: Restoration Tips and Techniques  (Read 4903 times)
Offline lrutt
Re: Restoration Tips and Techniques
« Reply #25 on: March 19, 2008, 11:51:27 AM »
I like to get the bike completely mechanically sound, running, and road worthy before I tear down for cosmetic work. That way you are much less inclidned to scab up the bike fixing mechanical when it's all nice and painted.
For me it's not about a 100 point concours resto. It's about either evaluating if it can be brought back to life with minimal repaint such as my recent commando. Kept the tank and side covers original even with a few blemishes and repainted frame and polished alloy.
Just polishing and keeping fresh like my K6. Just keeping it clean and running great, even with patina on the plating etc.
Keeping it completely original with all it's fine patina and blemishes but mechanically perfect like my Trophy, right down to everything except tires and air filters. And they are as original as can be.
A frame up job like my Dream including exhaust, paint, seat, and tires as close to the original white walls I could get.
Or mostly original with sensible updates like the Lemans, departure from stock would be all SS allen hardware, SS brake lines.
Then there is the K8, Not original really in any way but tastefully done so as to fully reflect the original bike, just happens to have a side car on it. Most people cant tell it from stock. Paint and pipes and seat are the only real departures. I didn't want to spend the bucks on pipes and worry about decals etc.
So you really need to understand exactly what you want to do, what you have, what it's worth, and what you are going to do with it. I ride all my bikes. I make sure I switch all brakes over to dot 5 to keep them maintenance free, make sure they have AGM batteries in them, I keep a special mix of fuel in them (premium gas, stabil, lead additive, and 70:1 two stroke oil mix) that keeps tanks from rusting and everything fresh. I always drain carbs if I'm not going to ride the bike again in 4 or more weeks, that way I don't have gummed up carbs, ever.
Soda blasting is your friend on cleaning parts without eating them up much. Good old duplicolor engine paint looks real good, close to original, is cheap, and goes on easy. I tend to use Acrylic Enamel with hardner to paint body parts. It's tough, easy to apply, cheap (I get it over the internet). I shoot all my own work, you can easily teach yourself (I did). Lots of info on body shop sites. Spray guns are cheap. My old CH gun must be 30 years old but still does the job and was only like $20 back then. Prep and clean air are the secrets. Sometimes I paint frames with a rattle can (Norton, K8) as that more closely matches the original (not too much gloss). Sometimes I just want a nice shiney bike so I shoot the whole thing with enamel (Dream, LeMans). Some good polishing wheels and compound are good to have as well. Most original bikes did not come with mirror finishes but a nice satin finish to the AL. That is easy to reproduce with a wheel. Some guys get carried away with polishing. Unless you clear it it won't last anyhow. And if you do clear it, you will end up stripping it and redoing it before long as clear just does not last. Didn't when the bikes were stock and has not improved any since it seems.
So what is your goal?
« Last Edit: March 19, 2008, 12:20:16 PM by lrutt »
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #26 on: March 19, 2008, 02:57:22 PM »
         Irutt,   That IS some fine collection you have there. While they ALL are fine looking specimens, that Norton Commando sure caught my attention. 8) ;)
         Of three bikes in my collection of "Project Bikes"
 1. The 74' CB450 - Close Restoration
 2. The 69' SL350K0 - Close Restoration
 3. The 63' Cb77 Super Hawk - Fixed up with the basic look, but with
     some mods
     I've got others, but didn't want to load you all up with all that.
Member # 1969
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #27 on: March 19, 2008, 05:22:46 PM »
Duplicolor 500 degree silver is a very good match. Looks better after some heating cycles. Spent several hours cleaning every last crack with Prepsall and a toothbrush. With careful masking, it came out very nice. The dipstick has since been replaced
Fonda Honda
Offline bill440cars
« Reply #28 on: March 21, 2008, 10:15:47 AM »
        Nice job on THAT one! A lot of heavy polishing looks good and all, but I would think that the approach you went for on that bike, is more of a "Restored Look"! Very nice work indeed. Thanks for posting! ;)
                                   Later on, Bill :) ;)
Member # 1969
Offline grumburg
« Reply #29 on: March 22, 2008, 05:39:53 AM »
It looks less "restored " than the pictures show. It is also easier to clean .
Fonda Honda
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #30 on: March 22, 2008, 06:57:02 AM »
At risk of being repetitive I don't think it can be stressed enough the importance of getting appropriate shop manuals for the bike being worked on. I try and source as many different manuals as possible since each may have a different viewpoint on performing a particular procedure. Also being a member of the owners club really helps (thanks one and all!). I'm getting the Commando back together so I can tuck it in the corner of the garage, and finding it to be quite straight forward since I have access to over 30 years worth of tips from  people who have gone down the same road.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline bill440cars
« Reply #31 on: March 31, 2008, 05:59:00 PM »
        I want to thank everyone for their input on this. I've got the SL350K0 that I'd like to do a restore on, but it will be drawn out, as things like the rear rim and side covers are missing. Not sure just what else is missing until I can do a complete check. Never done an actual "Restore" before. I did build a 58' Jawa 125cc bike out of parts years ago, but there wasn't a bunch of spit and polish like I've seen here. At any rate, if anyone else happens to think of something that has been overlooked, sure appreciate it, if you'd throw it in the mix! :D
Member # 1969
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #32 on: March 31, 2008, 09:29:39 PM »
Bill,
There are a few things that you can't reasonable expect to do yourself including chrome and zinc plating. If you intend to do these things, start shopping around as the prices vary widely (probably the quality too!). Orlando obviously caters to the mouse crowd who don't require services like these. I would have probably been better off packing everything up and sending it to a more reasonable priced non-local place. Having said that, I am pleased by the quality so........  ::)
I also used a professional painter as my painting skills stop with a rattle can. Labor is where you will save bucks. Do as much as you can yourself. At least if you screw up, you'll know how to do it the second time!  ;D
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
