Author Topic: Andys CB810 K2 -updated 14 Oct 2024 - missing link!  (Read 170948 times)
So I opened up the K2 carbs tonight and found a few issues...evidence of brass-aluminum corrosion, and carb #3 had a bent float - probably explain why it was the cold cylinder at start up - surprised it wasn’t overflowing at idle. See pics below...
#2
The broken pilot jet
Explains the #3 plug...that I checked previously
Offline jaytee-nz
I might be seeing things, but the pilot jet on the right hand carb looks bent to me ?
Never noticed that...Ill take a closer look and let you know!
That pilot jet does look bent. Were you playing soccer with those carbs Andy??
Never touched them!
I may need your help though in extracting the broken one  :-X :-\
I have a spare set of carbs that I am hoping to install tonight and test ride tomorrow morning so will update here with progress.
« Last Edit: July 24, 2020, 06:35:33 AM by andy750 »
Online PeWe
If the bent looking jet really is bent, the broken jet might have been bent too. Can be why it broke.
Remove the other jets very slow. No quick twist.
Edit: Buy Keihin jets.
« Last Edit: July 24, 2020, 08:53:04 AM by PeWe »
Ok so...the pilot jet was not bent...optical illusion I think - see pics
All four carbs
Pilot jet on the right looks straight to me
Close up
Arrow points to jet in question
Switched the carbs and success!!! - no leaks on start up and test ride showed what I have been missing these last few months - snappy throttle, growl of the HM300s, fast acceleration - got it up to speed on the highway and was not disappointed. Smiling again!! Can’t wait for the next ride :)
Thanks for all the comments they really motivated me.
Post-highway ride
Offline Alan F.
Good news Andy!
Online PeWe
Quickly done too!
Offline knowsnothing
Re: Andys CB810 K2 road racer- updated 07.24.20 on the road again!
« Reply #286 on: July 28, 2020, 01:26:23 PM »
 Nice work young Andrew
1978 CB750k Blue - for sale
« Reply #287 on: July 28, 2020, 06:19:49 PM »
Thank you Treeve! I was over in your neck of the woods on Saturday morning at 8am....did the Blue Hills-Wollaston Beach loop from mine and back to test ride the K2. Passed with flying colours! Next time Ill shoot you a text before I head over. I was back home by 8:30 before the heat hit.
How is your bike coming along? Running yet? Need any parts?  8)
« Reply #288 on: July 29, 2020, 11:45:57 AM »
Let me know next time for sure.
The bike is finally running.  I still need to finish the tank and seat, but I have a stock tank and seat on it for now so I can get a few miles on it while i finish.
 Right now i am working on tuning.  It has a hanging idle issue I think is likely due to a lean condition, so I am working on that.  Still need to open it up on a highway, but its nice and peppy so far. I am just pumped it didn't grenade on first start up since i did do most of the work    ;D  .
« Reply #289 on: July 29, 2020, 07:57:55 PM »
Are the felts on the throttle shafts lubed? That can cause a slow return to idle.
« Reply #290 on: July 31, 2020, 07:12:57 AM »
Looks good Andy!
« Reply #291 on: July 31, 2020, 06:41:12 PM »
Looks good Andy!
Thank you! Big relief getting it back on the road. Now thinking about tires - what do you like? I always buy BT45 but feel like a change for this bike
Offline Alan F.
« Reply #292 on: July 31, 2020, 07:11:21 PM »
BT-46 is available, I haven't heard any ride reports though.
« Reply #293 on: July 31, 2020, 09:46:30 PM »
Someone recently mentioned putting a new BT-46 on the rear of their CB. Do not recall whom. Would a Google search find reference to BT-46?
Offline Kevin D
  • SE Michigan
« Reply #294 on: August 01, 2020, 03:10:31 AM »
https://grippingstories.com/articles/2019/battlax-bt46-the-new-reference-bias-touring-tyre
BT46: wet road performance improved about 10% by modification/enhancement of sipe design.
At least, that’s the Bridgestone pitch.
UM application, tube or tubeless.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Online PeWe
« Reply #295 on: August 01, 2020, 07:05:14 AM »
Rear with longer life would be fine. Over 4000 miles with some inspired accelerations.
« Reply #296 on: August 01, 2020, 08:09:13 AM »
 Happy to say the broken pilot jet has been extracted and Andy should have the carbs back very soon.
Online PeWe
« Reply #297 on: August 01, 2020, 09:47:44 AM »
Golden boy to live that close to a superb support, huge knowledge and fantastic craftsmanship!
Good friend too!
« Reply #298 on: August 01, 2020, 01:56:00 PM »
Good friend too!
Very well said Per and couldn’t agree more. I first met Mike about 15 years ago through the forum and it has been an honour to know him.
« Reply #299 on: August 01, 2020, 01:56:46 PM »
Thank you Mike!!!!   ;D
