Author Topic: What leads do I test?  (Read 945 times)
Offline LoopsAndLogic
  • Dang IT!!!
« on: March 17, 2008, 02:18:47 PM »
I'm looking at another ignition switch base that is aftermarket since mine is showing some wear with
it's turning action the fact that it's stained badly from the bike sitting outside from the original owner.
But what came to mind, was, couldn't there be a build up of resistance in the switch base from old use??
What leads should I check with my Multi-meter in the Ohms setting?
Thanks for the help on this, as there's like 5 prongs!!!
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline mark
Re: What leads do I test?
« Reply #1 on: March 18, 2008, 01:25:44 AM »
.....But what came to mind, was, couldn't there be a build up of resistance in the switch base from old use??
dirt, grease, crud, oxidation.... make good insulation at times.
5 prongs... IG - black wire... BAT - red... TL1 - brown/white... TL2 - brown (1 wire to 2 prongs)
Key off - no connections... on - BAT to IG, TL1 to TL2... park - BAT to TL2
Good luck.
F you mark...... F you.
