Author Topic: Who makes the best float bowl o-rings?  (Read 929 times)
Offline ralt12
« on: March 18, 2008, 04:54:41 PM »
The ones from Versuh are too long out of the box, and making them fit when you're doing jet changes is , well, just a @#$%^&*....
(CB550F)
Offline Jeremiah
    • North City Vintage Honda
Re: Who makes the best float bowl o-rings?
« Reply #1 on: March 18, 2008, 06:35:39 PM »
Versah?  I thought they just made engine gaskets?   K&L 550 gaskets don't really fit.   Keyster for the 550s and 77-78s fit good.
Offline LMAERO_396
  • Cafe Fighter Pilot
« Reply #2 on: March 18, 2008, 07:03:47 PM »
my question is why do they make them round for a not-so-round shape, #@$%!!   :D
*My Rides*
2002 Ford F-250 CC 7.3 Diesel
2008 HD Dyna Street Bob
1974 CB550 Project
1971 CB175 Project
Offline Red750K1
« Reply #3 on: March 18, 2008, 07:05:40 PM »
Back when I had my '73 CB500 I did the carbs, I feel your pain, those stupid things dont want to stay in. I figured out a trick that worked however:  I used tape (masking tape because thats what was within arms reach when I was doing it). I taped the o-ring bowl seal into the grove on the bowl on the corners and once between each corner then screwed it onto the carb loose. Just use a little tiny bit of tape and dont have it hanging into the bowl. Once the bowl was on but not torqued down, I slid the tape out and that left the o-ring in the groove. Voila! Torque down the screws and smile  ;D
« Last Edit: March 18, 2008, 07:07:50 PM by Red750K1 »
Offline bender01
« Reply #4 on: March 18, 2008, 08:43:15 PM »
I just recieved a whole set of o-rings to rebuild a set of four carbs for less than 20$.  The float bowl rings laid right in fine... as did the main jet,float jet ,and the drain. His address is
kthunter01@sbcglobal.net
hes also known as honfours on ebay. I hope he gets put on FAQ where to buy parts.. for carbs...
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
