Author Topic: CB750 is it an import?  (Read 2692 times)
ian1976
« on: August 09, 2005, 12:34:51 PM »
Hi there I wonder if anyone can help me, I have bought an unregistered Honda CB750 in the UK as a project bike.  Someone told be me that it may be an American import. The numbers are
The numbers are Chassis number (VIN)- 1031114
Engine number - CB750E - 2544770
It also has year of construction 19
Apparently UK bikes do not have the year of construction bit.
Any help is appreciated
Ian  ???
Offline Clyde
Re: CB750 is it an import?
« Reply #1 on: August 09, 2005, 04:23:44 PM »
It looks like a 1976 F1 from the numbers. The frame/VIN should be CB750F-1031114. If there is no "F" it is a K0 with a F1 engine.
From what I understand the US models of the F1 used a different numbering system which commenced at CB750F-2000003, but used the same engine numbering as the rest of the world.
Funny because the 1975 F used the numbers CB750F-1000002 to CB750F-1015054 and was only sold in the US
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
ian1976
« Reply #2 on: August 10, 2005, 01:30:45 AM »
Thank you Clyde.  The frame is older than the engine as a previous owner replaced the engine.  Do you feel that the frame is an American frame?
Offline Clyde
« Reply #3 on: August 10, 2005, 01:56:25 AM »
Ian, What exactly is the frame number including CB750 "F"-?
Does it have a disc brake?
SOHC4 #1909
ian1976
« Reply #4 on: August 10, 2005, 02:31:51 AM »
I'm at work at the moment but will have a look later - thank you :)
ian1976
« Reply #5 on: August 10, 2005, 12:51:26 PM »
Hi
There is no mention of a F in the frame number but the bike does have a disc on the front.  The back is drum
KRs
Ian
Offline Clyde
« Reply #6 on: August 10, 2005, 06:52:20 PM »
It must be a K0 frame with a F1 engine. Good combination.
I cannot help with identifying if it is an import
SOHC4 #1909
Bobby
« Reply #7 on: August 10, 2005, 08:33:18 PM »
Most if not all of these CB750's originated in Japan.  So, taking into consideration the country of origin, any sovereignty possessing an alleged CB750 would, under the SOHC treaty of 1969 must be by law considered an import.  However, numerous amendments adopted since the initial treaty, exclude Iceland and Switzerland.  Armed with this living history, I must conclude that your CB750 is in actuality, a nomad in search of permanent citizenship.
Offline mick750F
« Reply #8 on: August 10, 2005, 08:43:28 PM »
   And possibly a bastard child...
Glosta, MA
ian1976
« Reply #9 on: August 11, 2005, 12:18:53 AM »
Thank you for your help
Ian
« Reply #10 on: August 11, 2005, 06:53:01 AM »
Ian, give me a ring on 07795162623 any evening sunday to thursday and i will tell you how to go about registering it as i have done many.
