Author Topic: How long does a new rear sprocket last?  (Read 3333 times)
Offline L.A. Nomad........
  • 1976 CB550 K
« on: August 09, 2005, 02:08:54 PM »
About how long should a rear sprocket last? I always tigten my chain and ride at least 44miles each day. I've had it about 3 months and it looks beat now,,,,,,,,,,,,,,,,,,, Ok, I leave loose once in a while and dirve hard.......
Nomad
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
bike54
Re: How long does a new rear sprocket last?
« Reply #1 on: August 09, 2005, 02:19:13 PM »
hi
how often do you oil it?
 i would have thought unless its a cheap after market one longer than that think about a product call  a scott oiler avalabe in the uk for about £60 $130 it automaticaly oils the chain and extends the life of chain and sprockets up to 7 times maybe 25 thousand miles plus dont know if its avalable in your part of the world google search for it
it will give you all the info on it another thought when the rear sprocket was changed was the chain if not you get massive where as they bed together and if the chains at the end of its life it will soon bugger your sprocket up
bike54
« Reply #2 on: August 09, 2005, 02:53:16 PM »
That's a loaded question. Steel or aluminum. Cheap part or good part?(That goes for both sprockets) What type of chain? What type of lube. I've had chain/sprockets go 15,000 miles(RK LFO chain, OEM front, Sunstar rear steel) on my FJ1200 with over 150HP and 10,000 miles(OEM chain/sprockets) on my Busa. The busa chain and sprockets were still in very good condition  too but the chain has a reputation for breaking when the engine gets over 170HP.
Buffo
« Reply #3 on: August 09, 2005, 03:05:21 PM »
If your chain is too tight it will wear the #$%* out of your sprockets
Don
« Reply #4 on: August 09, 2005, 03:19:33 PM »
Hey Head Man,  have you thought of detuning the Busa to get longer chain life, ;D
« Reply #5 on: August 09, 2005, 05:25:29 PM »
Are you using chain wax or chain lube?
O ring chains survive with wax only.  But, not standard.
Was the chain allowed to run dry?
Did you get sand or dirt on it?
Was the new sprocket used with a worn chain or front sprocket?
The pin/roller spacing increases on worn chains and the sprocket wears to match the worn spacing.
I change sprockets every second chain.  First chain (DID) usually goes 15K-20K miles (depending on lube frequency).  The second chain lasts 10-15K because of the worn sprockets.  I use steel sprockets.
« Reply #6 on: August 09, 2005, 06:24:23 PM »
Why detune when you can upgrade parts! ;) ;D
« Reply #7 on: August 11, 2005, 11:35:04 AM »
Just pulin y leg. ;D
