Author Topic: Brazing  (Read 4564 times)
Re: Brazing
« Reply #25 on: March 18, 2008, 09:43:47 AM »
Indian & Harley frames were furnaced brazed for a long time,
but,
I think they did have the odd plug weld.
I dont think brazing a frame has any strength issues if they are slip fit joints, then brazed.
On vintage bicycle frames they are often brazed which leaves a nice clean joint, and they hold up very well.. I probably could show a dozen examples tha are 50 years old if you come to visit..
Oh and St Pattie is a burger.. not the Irish dude..kghost..
Re: Brazing
« Reply #26 on: March 18, 2008, 10:43:06 AM »
Hate to dissapont but ALL the old Brits were Brazed BUT most tube joints were "socketed" (tube inside a hole) not but jointed
Offline Gregorymoto
  • SOHC Aficionado
Re: Brazing
« Reply #27 on: March 18, 2008, 06:13:09 PM »
My last comment.
Well thank god all the old bike builders figured it out and did it right and thank god for modern day welding technology and Miller Electrics.
Yep, i have issues with this sort of stuff.
Offline kghost
Re: Brazing
« Reply #28 on: March 18, 2008, 07:56:17 PM »
Amen
Stranger in a strange land
Offline mark
Re: Brazing
« Reply #29 on: March 18, 2008, 10:36:40 PM »
Until this evening, I hadn't brazed anything in ages....
Sandblasted the heck out of my header and found one little pinhole a few inches ahead of the collector. The mig would probably just make the hole bigger. GAG!!! No O2 in the tank, either. Found that a propane plumber's torch would get the area bright red - enough to melt a puddle of silver brazing wire on there. As long as the pipe doesn't get red-hot that far down, it should stay there ok. I hope.
As for seat and tank mounts, I'd weld them. Tank repairs? That's something else entirely.
....thank god for modern day welding technology and Miller Electrics.
The Lincoln aint bad either. ;)
Happy trails.
F you mark...... F you.
1976Thunder
Re: Brazing
« Reply #30 on: March 20, 2008, 05:08:46 PM »
Thanks guys and yes I was talking about oxyacetylene. I have a real nice set up that I use for building bicycles. I have ordered some high tensile rod. This is going to be the first bike I build and not just motor and one thing I have learned from years of doing it wrong is ask someone that knows first.
