your best buddy in the whole world is going to be an 18mm spark plug socket. It kinda has to be specifically a plug socket, because the top edges of a regular socket hit against the valve cover. What also works is to stick the socket down onto the plug, make sure it's on there good, THEN attach your 2ish" extension, then your ratchet. but any way you do it it's a pita. that's why I went to iridiums. In theory they won't foul as easily.
Well, THAT'S one tool I don't have as of yet. I tried about everything else, including a regular 18mm deep one, but with no results. I got frustrated and put it aside for a bit. I'll have to get one of those sockets and finish it up. Definitely don't want to have to be replacing plugs any more than necessary, so I'll be checking into THOSE plugs as well. I appreciate the input Kit. After I get this one running good and smooth, I'll be looking to do a repaint and have to decide where I want to go with that.
At the present, I don't have ANY idea what color(s) or scheme that I want to do.
Probably just need to sit down, look the bike over and try to picture it in my mind AND do some searching of others. I'm not doing a restoration, so those colors are out. Right now, I'm thinking a red or maybe a blue. But by the time I end up doing it, there's no telling just WHAT color it will end up being.
Think I'll check the 650s in the gallery for starters.
Thanks again, Bill
