Author Topic: Detonation prevention questions -retard timing or higher grade fuel?  (Read 1636 times)
Offline hapsh
    • Listen to the latest tracks from JazzCancer
I checked my plugs on my 550 after a 60 mile ride at 75-80 mph and found that the color is just where I think it should be, right at #14 on this chart http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html .   However even though I did not notice any pinging I found a small aluminum ball on two of the plugs near the center insulator.  I have read that that is common on motors that are jetted very close to max power, they will sometimes show subtle signs of detonation.  The bike runs great however, I don't hear any pinging at all (I don't know if I could hear it at 80 mph anyway).  But, should I be concerned?  The timing is spot on for static and advanced.  I am currently running 87 octane which was said to be OK for these bikes in the FAQ.  My question is; should I slightly retard timing so that it is not quite at the full advance marks to be on the safe side?  Or should I pony up for midgrade?  I am shooting for max fuel economy over performance on this bike so I have already been thinking of retarding the timing anyway.
'71 CB500/550, '72 CB450, '79 RD400 Daytona, '90 FZR600R
Offline KeithB
Re: Detonation prevention questions -retard timing or higher grade fuel?
« Reply #1 on: April 02, 2008, 01:01:49 PM »
Try running higher octane fuel for a while.
Nanahan Man
Offline dusterdude
« Reply #2 on: April 02, 2008, 01:23:29 PM »
you can try that,but you may be a tad lean too.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: April 02, 2008, 02:05:36 PM »
Is it a stock motor and set-up?
Offline hapsh
« Reply #4 on: April 02, 2008, 03:38:55 PM »
I am very happy with its performance and it is quite a way off from being lean enough to be the cause of detonation.  I will try retarding the timing a few degrees and also try higher octane gas.  I have DE7 plugs in it now for the cold months, but will be putting back the DE8's in May.  The motor has 4-1 exhaust and Uni pods.  However I worked quite a bit to get the jetting adjusted to compensate for these changes. I've done plug chops and adjusted jetting until it ran its best.
Offline johnny_from_bel
  • Member #158
« Reply #5 on: April 02, 2008, 03:46:59 PM »
plugs nr 2 and 3 ?
Offline hapsh
Offline merc2dogs
« Reply #7 on: April 03, 2008, 08:16:47 AM »
 Believe he's asking if they were plugs no 2 & 3 that you found the aluminum balls on. The outer cylenders run cooler than the inner two.
Ken.
  • Member #158
« Reply #8 on: April 03, 2008, 09:07:39 AM »
Ken.
Correct ! Did you find the aluminium balls on plus nr 2&3
Offline hapsh
« Reply #9 on: April 03, 2008, 09:28:02 AM »
No, they were on plugs 1 and 4.  I checked timing again to see if 1-4 are slightly more advanced than 2-3 but it looks right on the mark at full advance.  I also thought about richening the mixture a bit to help keep the bike cooler this summer but my main goal is to maximize fuel economy.  That is why I am thinking of playing with timing retard.  I am going to the junk yard to pick up a used 550 timing advancer to modify today.  I am going to play with the spring tension and the full advance stops so I can keep the timing normal at idle but just a bit retarded at full advance.
  • Member #158
« Reply #10 on: April 03, 2008, 03:06:30 PM »
Its a timing issue.
Running lean does not saves much on fuel. Better to run a bit rich and advance timing.
