Author Topic: How to clean off old gaskets?  (Read 3955 times)
BarryKelly
« on: April 10, 2005, 02:16:37 PM »
Hey all.
I'm just in the process of putting in a new cam-chain and tensioner.  So far everything is going smashingly well, but I'm wondering how to clean off the old gaskets.  For the most part, they simply peeled off leaving a nice shiny, clean surface.  However, in some spots they did not peel off, not at all.  I tried scrapping them off, but can't really do so without scraping the under surface.  I'm wondering, is there a good way to take them off chemically? (i.e. spray on something that will soak in and all them to just wipe off?) or is there a way to scrape them off gently?  Finally, how badly can I scrape the surface before I'll get leaks when I put it back together?  Obviously a big scrape would not be good but would lots of little scratches hurt?
Anyway, thanks a bunch
Barry
1978 CB550
Offline fergie
Re: How to clean off old gaskets?
« Reply #1 on: April 10, 2005, 02:40:14 PM »
use a plastic scraper,try to put as little scape marks on as possible.absolutly no gouges.
The most interesting man in the world
Offline frostypuck
« Reply #2 on: April 10, 2005, 03:24:57 PM »
I used a spray called "Spray Gasket Remover" I don't remember who makes it, but it's in a big industrial-sized green can. May have been 3M. Spray it, it bubbles, and 3-5 minutes later I used a plastic knife like you get at a picnic.
I took my can from work, but checking at NAPA should provide good results.
Good Luck,
Chris in Boston
Boston, MA, USA
screwtheman
« Reply #3 on: April 10, 2005, 04:10:46 PM »
Yeah, I have some Napa brand gasket remover. It takes a couple of applications to get the tough stuff off (like head gaskets). The longer you let it set, the more it turns the gasket to goo. Good luck! ;)
aglick87
« Reply #4 on: April 10, 2005, 07:31:33 PM »
I used the gasket remover from permetex and let it soak 5-10, then have at it with a new razor blade.  Just be careful not to dig into the surface.  Just be careful not to overspray onto the painted case as this stuff doubles as a great paint thinner...... :-[
BarryKelly
« Reply #5 on: April 11, 2005, 01:13:33 PM »
Thanks everyone, that sounds like what I'll do!
Cheers
Barry
Offline cb650
« Reply #6 on: April 11, 2005, 01:46:35 PM »
I use a die grinder with a scothbrite pad.  You have to be carefull not to take off alluminum.
                     Terry
