Author Topic: Will this chain work for my bike?  (Read 1373 times)
Offline cbass*gxc
    • My Pics Page
« on: March 31, 2008, 12:41:05 PM »
I have been reading all day about chains since I am needing one and came across this on ebay.  I was wondering if it would work for my 78 550k?
http://cgi.ebay.com/ebaymotors/Yamaha-YZ125-YZ-125-250-WR-TT-520-112-Drive-Chain-New_W0QQitemZ180227133618QQcmdZViewItem?hash=item180227133618
Its says it is for a yamaha yz but it is a 520 non o-ring and its 112 links long.
Thanks
Jay
Re: Will this chain work for my bike?
« Reply #1 on: March 31, 2008, 01:06:25 PM »
The stock 550 uses a 530 chain.  Are you planing to replace your sprockets to fit the 520 chain?
Offline cbass*gxc
    • My Pics Page
« Reply #2 on: March 31, 2008, 01:08:40 PM »
Nope.  I thought I read that a 530 chain would rub but I must have been mistaken.  So I guess a 530 non o-ring chain is the key?
Maybe something like this.
http://cgi.ebay.com/ebaymotors/530-DID-O-RING-CHAIN-118-LINKS-NEW_W0QQitemZ200211217362QQcmdZViewItem?hash=item200211217362
« Last Edit: March 31, 2008, 01:10:38 PM by cbass*gxc »
« Reply #3 on: March 31, 2008, 01:14:29 PM »
A 530 oring chain will rub unless you make modifications to the front sprocket to gain about 1/8 inch extra clearance from the engine casework.
A 520 oring chain will work if you replace the sprockets to match the 520 roller width.  Same is true for 520 standard chain.
A 530 standard chain was the stock chain on the CB500 and 550 and fits without issues, of course.
Offline cbass*gxc
    • My Pics Page
« Reply #4 on: March 31, 2008, 01:17:22 PM »
Thank you very much.
So will any 530 chain fit as long as it is enough links?
PS TT you know the answer to my other post?
« Reply #5 on: March 31, 2008, 01:26:03 PM »
You're welcome.
Yes.
What other post?
Offline cbass*gxc
    • My Pics Page
« Reply #6 on: March 31, 2008, 01:28:07 PM »
Offline cbass*gxc
    • My Pics Page
« Reply #7 on: April 03, 2008, 10:10:04 AM »
So this chain here says it is for our bikes but it is an o-ring chain.  Will this work without the clearance issues?
http://cgi.ebay.com/ebaymotors/HONDA-CB400-CB450-CB550-CB750-530-100-O-Ring-Chain_W0QQitemZ180229638657QQcmdZViewItem?hash=item180229638657
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: April 03, 2008, 10:13:29 AM »
No.  Do not use an o-ring chain on a 550.  Like TT stated, there are chain width clearance issues on the 550 and it will most likely rub a hole in your engine case.  Just go with a standard chain, or if you feel like a bigger project, get the 520 sprockets and a 520 o-ring chain.
Offline cbass*gxc
    • My Pics Page
« Reply #9 on: April 03, 2008, 10:22:28 AM »
Ok so how about this chain that is an rx-ring?
http://www.mawonline.com/rk.htm
(42555)     $66.95 RK 530XSO RX-Ring Chain 100 Links Mfg.#: 530XSO100
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: April 03, 2008, 10:27:16 AM »
You seem determined to ignore good advice. ???
If you want to run anything other than a standard 530 chain, you'll either have to switch to 520 sprockets and chain, or deal with a hole in your crankcase.
Offline cbass*gxc
    • My Pics Page
« Reply #11 on: April 03, 2008, 10:29:39 AM »
Those were the chains that are talked about in the faq's.  If its a factory chain then I will get a factory chain.  Is there a place to get standard chain without having to order it from honda?
Scratch that I found these on ebay and at 100 links they should fit with a few taken out.
http://cgi.ebay.com/ebaymotors/DID-530-Standard-Motocycle-Chain-100-Links-New_W0QQitemZ320132148619QQcmdZViewItem?hash=item320132148619&_trksid=p3756.m20.l1116
« Last Edit: April 03, 2008, 10:34:16 AM by cbass*gxc »
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: April 03, 2008, 10:37:16 AM »
I always get chains from www.loudfastugly.com.  If I remember correctly, he sells Tsubaki standard chain for $22 plus $9 shipping.
Offline cbass*gxc
    • My Pics Page
« Reply #13 on: April 03, 2008, 10:39:31 AM »
Thats even better.  I just didnt want to pay $100 from the honda dealer.  And didnt know where to look.
