Hell, I'm in love with RustyOlive's CB! THAT is definitely in my top 10.
Quote from: DORIGTT on August 22, 2013, 02:38:29 PMHell, I'm in love with RustyOlive's CB! THAT is definitely in my top 10.Bahaha! Thankyou sir! Olivia is almost done. Can't wait to rip up the streets again.
What size rim and rear tire and how did you go with chain alignment..?
Quote from: Retro Rocket on August 22, 2013, 03:56:36 PMWhat size rim and rear tire and how did you go with chain alignment..?180/55zr 18. on a 18x5.50" rimOffset front and rear sprockets from Cycle X
Quote from: CB750 Cafe Racer Fan on August 22, 2013, 04:05:24 PMQuote from: Retro Rocket on August 22, 2013, 03:56:36 PMWhat size rim and rear tire and how did you go with chain alignment..?180/55zr 18. on a 18x5.50" rimOffset front and rear sprockets from Cycle XRO, how tight is the fit and how much frame clearance for the chain, Added a spacer .? 10mm? Is that in a stock swingarm..?
Quote from: Retro Rocket on August 22, 2013, 04:10:34 PMQuote from: CB750 Cafe Racer Fan on August 22, 2013, 04:05:24 PMQuote from: Retro Rocket on August 22, 2013, 03:56:36 PMWhat size rim and rear tire and how did you go with chain alignment..?180/55zr 18. on a 18x5.50" rimOffset front and rear sprockets from Cycle XRO, how tight is the fit and how much frame clearance for the chain, Added a spacer .? 10mm? Is that in a stock swingarm..?3/8 off set front sprocket. 10mm spacer between rear sprocket. Gives me about 6-8mm clearance between chain and frame. 4-5mm clearance between chain and tire (on a 180 tire) Swingarm is from scratch.
Quote from: RustyOlive on August 22, 2013, 04:29:18 PMQuote from: Retro Rocket on August 22, 2013, 04:10:34 PMQuote from: CB750 Cafe Racer Fan on August 22, 2013, 04:05:24 PMQuote from: Retro Rocket on August 22, 2013, 03:56:36 PMWhat size rim and rear tire and how did you go with chain alignment..?180/55zr 18. on a 18x5.50" rimOffset front and rear sprockets from Cycle XRO, how tight is the fit and how much frame clearance for the chain, Added a spacer .? 10mm? Is that in a stock swingarm..?3/8 off set front sprocket. 10mm spacer between rear sprocket. Gives me about 6-8mm clearance between chain and frame. 4-5mm clearance between chain and tire (on a 180 tire) Swingarm is from scratch.Thanks mate, I'm doing similar things with a 750 which has slightly more room, nice to know that 10mm is all thats needed, I had worked that out by measuring but seeing it is even better....
Quote from: Retro Rocket on August 22, 2013, 04:31:38 PMQuote from: RustyOlive on August 22, 2013, 04:29:18 PMQuote from: Retro Rocket on August 22, 2013, 04:10:34 PMQuote from: CB750 Cafe Racer Fan on August 22, 2013, 04:05:24 PMQuote from: Retro Rocket on August 22, 2013, 03:56:36 PMWhat size rim and rear tire and how did you go with chain alignment..?180/55zr 18. on a 18x5.50" rimOffset front and rear sprockets from Cycle XRO, how tight is the fit and how much frame clearance for the chain, Added a spacer .? 10mm? Is that in a stock swingarm..?3/8 off set front sprocket. 10mm spacer between rear sprocket. Gives me about 6-8mm clearance between chain and frame. 4-5mm clearance between chain and tire (on a 180 tire) Swingarm is from scratch.Thanks mate, I'm doing similar things with a 750 which has slightly more room, nice to know that 10mm is all thats needed, I had worked that out by measuring but seeing it is even better.... #$%*!! Sorry! Back track! 18mm off set in the rear!! Sorry. Brain fart.
You are almost correct. The swing arm is 1 3/4" longer than stock. Between the front off set + the swinarm lenght + the rear off set = straight chain line. I already had 200k on the bike with this set up. No problems and no odd wear lines on either sprockets.
You cant tell which engine by the serial numbers..?
What is it like to ride...cornering handling vs. straight-line? I would like to do something similar, but I know a lot has to be done to make it 'right'. Yours looks the part though. Also, why size front tire/wheel are you running?Thanks.
Are the XL500 shocks something like 15-1/2" long? Doesn't look 'jacked up' at rear though, maybe camera angle or is it really pretty level?
I dont think the 750 frame will give those frame clearance numbers that that bike got..sorry but you would have to put a D section in or a dogleg..
Quote from: 754 on August 22, 2013, 07:44:40 PMI dont think the 750 frame will give those frame clearance numbers that that bike got..sorry but you would have to put a D section in or a dogleg..550 and 750 frames are the same width apart. I ran a 750 swingarm in the 550 before. Exact fit. It will work.
Perhaps this 750 build will through some insight to the idea/inspiration. http://forums.sohc4.net/index.php?topic=65268.0
