Are you talking welding an Akront, or Sun or similar.. to save it?
I alway thought it might be weaker, as I am pretty sure they are factory welded, straightened, then heat treated. When you weld, the WAZ is most likely in annealed state.. plus, if you polish, you sometimes have color match/filler rod issues.
But then you know, Kosman used to widen a lot of Gixxer type mag, with a full weld around the wheel, both sides
seems to be a lot of wheel repair places these days, and modern bike wheels are very THIN..
I got a question, for you, as I have picked up a few wider wheels like 04 or O5 sportbikes, do you think I can still handmount tires, or is it easier on the rims, to do by machine.
I dunno what if find scarier.. mounting the tires, or thinking about folks doing 175 or more on them rims..
