Author Topic: "INSPIRATION GALLERY "  (Read 2230842 times)
Offline Ricky_Racer
Re: "INSPIRATION GALLERY"
« Reply #2625 on: August 03, 2009, 10:31:10 am »
Wow, TG, do you mean that Guzzi parts are plentiful in Italy? Now, that is really a surprise!
Granted, early Moto Guzzis are very cool, as is the later Daytona 1100. I saw some very fast M-G's at SPA, and the purple Guzzi race bike in the recent pics of this thread is one of the most beautiful bikes I've ever seen. And yes, I'd love to own/ride a Magni Australia.  But, affordable M-G bikes and parts are in short (read: expensive) supply here in "The Land of the Free and The Home of the Brave."
BTW, if you've got a couple extra M-G levered rear master cylinders available cheap, I could use a couple.  Grazie!  ;D  RR
Offline Beans
  • I play with grease every day.
  • 1975 cb550f
    • bean's place.
« Reply #2626 on: August 03, 2009, 11:18:00 am »
I love that purple Guzzi to I wish I could afford one right now but with me buildoing 2 cb550's its tight.
Keep it shinny side up.
Offline turboguzzi
« Reply #2627 on: August 03, 2009, 11:20:35 am »
No ricky, i meant also outside of italy.... overall, a 850 le-mans will be half the prize of a 750 SFC, Bevel 900 Duc or R90S in germany, UK or USA too, dont you agree?
You'd be surprised, but saw Guzzi stuff in the US that costs less than here....
I agree that guzzi parts will never be as pletniful as a SOHC's but they are still more affordable than BMW's, Duc's or Laverda's.
In any case, let me know which rear master you need. I recall there where two sizes. I fitted a V50 rear (the small one ) onto my LMIII after de-linking the brakes.
I often go to swap meets so couold look for one or two
TG
  • Be careful you might get a
« Reply #2628 on: August 03, 2009, 11:31:23 am »
I think it was Bob Cecchinni
 around 77/78...
 was in Custom Chopper mag
Thanks
Found this while googling
http://www.bikerhotline.com/classifieds/index.php?a=2&b=813
Offline Ricky_Racer
« Reply #2629 on: August 03, 2009, 11:39:11 am »
Thanks, TG. PM with photo link sent.  8)  RR
« Reply #2630 on: August 03, 2009, 11:44:12 am »
Rat, there is a verrryyy large x huge library of chopper factoids, in my head.. ;D
« Reply #2631 on: August 03, 2009, 11:57:07 am »
I figured, I can't believe you called that to the year and builder. ;D
Offline Alan F.
« Reply #2632 on: August 03, 2009, 12:40:14 pm »
btw: does anyone know if/what kawasaki wheels mount w/o mods?
Without mods likely not, but I'm keeping my eyes open for a set of 5 spokers from an 82-83 GPZ550, they're just right for stock tire sizes on 750's with 18" rears, I think they'll look trick on just about anything.  I understand that 84 GPZ's ditched the leading axle forks and these wheels will fit those forks, sounds like an easy swap.
I've noticed many aluminum swingarms from the GPZ's (305, 550, and the early ninja 600) are going very cheap too, maybe swapping over a K bike to this disk brake setup won't be too tough.
-A
« Last Edit: August 03, 2009, 12:54:15 pm by Alan F. »
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #2633 on: August 03, 2009, 12:44:35 pm »
-A
GPZ750's should work also. And the 1100's aren't that much different.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Alan F.
« Reply #2634 on: August 03, 2009, 12:58:47 pm »
Agreed, but I kinda like the 5 spoke wheels, the later and larger bikes went to a different style wheel.
Offline HavocTurbo
  • Can you tell?
« Reply #2635 on: August 03, 2009, 02:06:48 pm »
My 85 750turbo had the exact same wheel. Lots of guys arent too keen on the weight, especially on a turbo application. Might be able to find a set cheap.
09 XL883L - No Name
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #2636 on: August 03, 2009, 06:33:16 pm »
so, is i to understand the kawa (etc...) wheels are narrower than sohc and require some spacer to make up the diff? can't be that simple, right?
my plan still is aluminum rims and ss spokes. right after i sell my other kidney. but i still like the 'mag' look too.
$$ be tight these days.
1974 CB550K
                                  Your 1%er name
Offline HavocTurbo
  • Can you tell?
« Reply #2637 on: August 04, 2009, 08:07:12 am »
To be honest Bill I have never measured the hub differences. So actually being narrower might not be the case.
Front wheels obviously have to be centered between the caliper(s).
Rear have to be lined up with the chain, belt, etc. It is more often than not the rear which needs most spacer changing. It seems almost every make and model has a different spacing regardless of brand. You'd think it'd be easier to use the same "transmission housing" but I guess not.
09 XL883L - No Name
Offline Joksa
« Reply #2638 on: August 04, 2009, 08:59:12 am »
Me too :) I have adapted a 5 spoke wheel from gpz 305 with laser cut discs with larger OD
http://forums.sohc4.net/index.php?topic=32296.msg478190#msg478190
« Reply #2639 on: August 04, 2009, 09:35:20 am »
There is several kinds of Kawi mags..some 4 bolt, some with big hole in the disc, like around6inches, think they are off GPZ.
 Too bad you are not here, got a few Kawi mags at 75.00 for front, 1 rear with disc & caliper,  and a GPZ front end antidive with 5 braided lines(130.00)
 I have built lots of wheel spacers over the tears,usually have to make spacers to do a swap..
« Reply #2640 on: August 04, 2009, 09:37:38 am »
Hey, should we make a whole "Mags" thread because I have some questions too but it could get pretty involved along with several months of R/D if my idea can work.
« Reply #2641 on: August 04, 2009, 09:41:32 am »
Rat were you at the Tsawaessen swap? looking at my 350 2-1?
There is a mag thread, they alway need some machining, nothing ever fall in place..
« Reply #2642 on: August 04, 2009, 09:53:52 am »
I wanted to go but couldn't make it so now that wasn't me. I'll look for the mag thread. I'm thinking new carbon fiber or something super light. Does anybody make 18's with the newer super light materials?
« Reply #2643 on: August 04, 2009, 10:02:44 am »
i dont think you can touch carbon fibres for under 4K a pair...
« Reply #2644 on: August 04, 2009, 10:10:51 am »
Never mind ;D
I'll just stick to my ss spokes and aluminum rims idea then. ;)
Offline SUELZER
  • Active
« Reply #2645 on: August 04, 2009, 12:36:25 pm »
wonder what the $$$ on some of these rims might be?
http://www.oushun.com/html/AutoParts.htm
...any us-based sites that offer this type of selection?
1976 Honda 550F
1993 Ducati 900ss
1979 Honda 750F
« Reply #2646 on: August 04, 2009, 04:45:00 pm »
Almost a whole page with no pics.... whats going on guys.... :P
Offline Alan F.
« Reply #2647 on: August 04, 2009, 07:30:35 pm »
I can't believe that I didn't notice that.  I replied to one of your posts in that thread almost a month ago, how'd I miss those wheels?  I must have been distracted by your tank, not many like that around here.  How's your build coming along Joksa?
Thanks Havoc for the tip on the 85 750 turbo having the same wheels, I'll have to look around.
-A
Offline CBJoe
« Reply #2648 on: August 04, 2009, 07:44:21 pm »
Still no pics  ::)
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #2649 on: August 04, 2009, 08:02:03 pm »
