I am very happy with its performance and it is quite a way off from being lean enough to be the cause of detonation. I will try retarding the timing a few degrees and also try higher octane gas. I have DE7 plugs in it now for the cold months, but will be putting back the DE8's in May. The motor has 4-1 exhaust and Uni pods. However I worked quite a bit to get the jetting adjusted to compensate for these changes. I've done plug chops and adjusted jetting until it ran its best.
