Author Topic: starter drive removal and lite weight flywheel  (Read 3169 times)
superscarf
« on: April 04, 2008, 09:00:11 PM »
hello...i am a new member from east central Indiana...i am working on a couple old 750 cafe bike and need some help....i am removing all the electric starter and starter clutch from the engine....my question is ...do i need to plug the oil supply in crank that is left open when i remove the one way clutch...didn't know if it had enough loss to loose pressure to number 1 main....any info would be appreciated....thanks Bradley
Re: starter drive removal and lite weight flywheel
« Reply #1 on: April 04, 2008, 09:11:46 PM »
I would put a sleeve over it with a flange toward the main bearing, otherwise I think you will get a drop in oil pressure.
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: April 04, 2008, 09:49:05 PM »
Here's a couple of threads that mention this issue:
Running without a starter motor
Re: engine oil seals cb 750  (click the image links in reply #4 for pics of the spacer you'll need)
Hope this helps!
mystic_1
« Last Edit: April 05, 2008, 07:33:47 AM by mystic_1 »
- John Augustus Shedd
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #3 on: April 05, 2008, 07:15:54 AM »
Incidentally, welcome aboard!
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline lordmoonpie
    • Moonpie
« Reply #4 on: April 06, 2008, 08:10:26 AM »
Errr, don't you need the kickstart pinion gear to drive the oil pump?! I can see plugging the kickstart shaft hole and the starter motor hole gear hole make perfect sense and also removing the non-return mechanism on the kickstart shaft but if you take the whole lot out, what's going to drive the oil pump?
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #5 on: April 06, 2008, 09:04:08 AM »
We were only talking about the starter drive and crank are where starter gear is located.
« Reply #6 on: April 06, 2008, 09:33:56 AM »
Who needs that pesky oil pump anyway. Extra weight I say. ;) ;D
Offline lordmoonpie
    • Moonpie
« Reply #7 on: April 06, 2008, 10:42:20 AM »
...and once the pistons get hot enough they lubricate themselves  ;D
....for a short while  :D
1994 Ducati 888 SP5
Offline nickjtc
« Reply #8 on: April 06, 2008, 08:27:51 PM »
But all that depends on using the right oil. "I use__________________oil". Fill in the blank. Discuss.
That speck on the horizon is me heading for the hills. ;)
1977 Suzuki GS750
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #9 on: April 06, 2008, 08:43:15 PM »
Hell, I'll pull up a chair with a couple cases of beer....and sell tickets... ;D
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline lordmoonpie
    • Moonpie
« Reply #10 on: April 07, 2008, 06:48:00 AM »
In your best Irish accent.... feck oil? ;D
Maybe that's best reserved for Father Ted viewers...
1994 Ducati 888 SP5
« Reply #11 on: April 07, 2008, 07:00:28 AM »
Better pull up a chair and a brewery. ;D
Offline nickjtc
« Reply #12 on: April 07, 2008, 11:56:04 AM »
Whale oil beef hooked. (Say in your best Newfoundland accent.)
1977 Suzuki GS750
« Reply #13 on: April 07, 2008, 07:54:57 PM »
hey, wasnt this about leaving out starter gear??
why all the negativity??... ;)
>>>>>>>>>>>>>>>>>>>running>>>>>>>>>>> ;D
Offline ridgeline61
« Reply #14 on: July 14, 2009, 05:41:41 PM »
Ya, i did it on my 77K and my temporary solution to fill the hole was silicon. HAHA, maybe not a long term fix but it removes that heavy electric starter. I think there is a electric starter clutch block-off plate that is sold but whatever. Oil pressure is still good. Had to play with the wiring but just having a kick start is just way cooler!
Offline lordmoonpie
    • Moonpie
« Reply #15 on: July 15, 2009, 04:21:18 AM »
LOL! I once had a Minarelli racer where the kickstarter shaft was plugged with...a wine cork!  :D
1994 Ducati 888 SP5
