Author Topic: Final Drive Flange removal  (Read 1997 times)
Offline phactory
  • Motorcycle Rescue
« on: April 05, 2008, 09:24:43 AM »
Hello, I just removed the rear wheel on my 1971 CB750 K1 and want to remove the final drive flange. This is the part that the rear sprocket is bolted to. I thought that this part should basically pop out. Is there anything holding this in, besides 37 years worth of road grime? If there is something what do I have to do to remove it correctly?
TIA, Phil
Offline merc2dogs
Re: Final Drive Flange removal
« Reply #1 on: April 05, 2008, 09:41:30 AM »
just road grime and friction against the cush drive.
leave sprocket on for a handle and work your way around while standing on the tire or holding rim with your knees.
ken
« Reply #2 on: April 05, 2008, 09:43:21 AM »
Just pull it off.
There is a spacer goes into the bearing that likes to fall out and pick up dirt :o.. dont lose that..
Offline phactory
  • Motorcycle Rescue
« Reply #3 on: April 05, 2008, 09:34:44 PM »
Well I brought the wheels to my local Honda dealer to spoon off the tires and the mechanic FINALLY got it off! It put up quite a struggle. I think the major problem was the o ring on the outer portion where the bearing is was really swollen. I thought these things usually fell out. ???
Thanks, Phil
« Reply #4 on: April 05, 2008, 09:41:28 PM »
I can assure you that if you lit up the tire often, this would never be a problem.. :o
Never heard of one that stuck.. next time put a 2x4 across the tire on each side of the sprocket & pry it off..
Offline phactory
  • Motorcycle Rescue
« Reply #5 on: April 06, 2008, 08:23:04 AM »
The problem is that the bike hasn't moved in at least 14years. I think the mechanic was just as surprised as you were!
Phil
« Reply #6 on: April 06, 2008, 09:21:27 AM »
Phil,
I used to have a similar bike - it was pristine but had sat for 15 yrs and EVERY bolt was stuck on that bike. Made every job so much harder. Good luck with it!
cheers
Andy
Offline phactory
  • Motorcycle Rescue
« Reply #7 on: April 08, 2008, 07:52:24 AM »
Andy,
 Luckily the flange has been the hardest part to remove. I brought it into work and cleaned it off in the parts washer and it now looks brand new Thank god for chain lube!!
 Hey I sent you a PM, did you get it?
Cheers, Phil
Phil,
cheers
Andy
« Reply #8 on: April 08, 2008, 07:53:15 AM »
Sorry for the delay Phil Ill go reply to it now.
cheers
Andy
