Author Topic: Trick Tappet covers for Honda Fours  (Read 8563 times)
« on: April 05, 2008, 09:36:14 AM »
I am working on a new design for tappet covers.
It will not use a hex for tightening, neither internal or external.
It will be a very clean design, that will look killer on choppers and some stockers.
I have built a prototype, but am still working out the torqeing  procedure.
I may sneak on a pic soon, think a SOHCer is popping in for a visit today.... maybe we can get a sneak preview..
Offline mystic_1
  • 1970 CB750K
Re: Trick Tappet covers for Honda Fours
« Reply #1 on: April 05, 2008, 10:40:11 AM »
Tease!
PICS!
 :D
mystic_1
- John Augustus Shedd
Offline LMAERO_396
  • Cafe Fighter Pilot
« Reply #2 on: April 05, 2008, 04:45:01 PM »
 8)
*My Rides*
2002 Ford F-250 CC 7.3 Diesel
2008 HD Dyna Street Bob
1974 CB550 Project
1971 CB175 Project
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: April 05, 2008, 04:58:47 PM »
Shouldn't require much torque. They are frequently over-tightened. Look forward to seeing them.
« Reply #4 on: April 05, 2008, 06:01:53 PM »
Yes they dont require much torque, however I am not convinced finger tight wil hold, so I am working on a tool.
Pic will be posted later tonite.
Offline 1080
« Reply #5 on: April 05, 2008, 09:32:15 PM »
Cool 750 tappet covers.
Your input.
fuzzybutt
« Reply #6 on: April 05, 2008, 09:57:52 PM »
those are cool as hell! i'd put em on my project 750
« Reply #7 on: April 05, 2008, 10:10:57 PM »
I will probably make a tach plug to match.
I have run one type of the market and like them at first, but in the long run, they look liked added on bling that does not make the valvecover look any cleaner.. so I went back to chromed stocker... so I thought long & hard to come up with something that fits and blends in rather than  stick out like an obvious add-on.
I will work on production detail.. can be in production soon.. do them inhouse..
Offline Aaron J Williams
  • Old Biker
  • Member # 725
    • Dude's Garage
« Reply #8 on: April 06, 2008, 06:33:45 AM »
Do they have to have that point in the center? They look good but the rest of the valve cover is all rounded so maybe if the covers were rounded too then they would look more like the valve cover? IDK, just thinking aloud.
There are old bikers and there are bold bikers but there are very few old, bold bikers.
Quote from: Gordon
Not doing what you can to make your bike ride-able during the best riding months of the year kind of defeats the purpose of owning it in the first place.
Offline eurban
« Reply #9 on: April 06, 2008, 07:01:58 AM »
Whatever you do, don't go this route! This (very) limited market is already cornered by Cyclexchange . . .
« Reply #10 on: April 06, 2008, 08:40:59 AM »
I could make a domed one as well, it would be more appealing to a more stock bike or cafe.
I fygure on the one shown to do a version first that would look nice on choppers without being too in your face.
Them other ones, they,  umm ....really stick out..
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #11 on: April 07, 2008, 01:36:21 AM »
Stupid question:
How do you undo them?
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #12 on: April 07, 2008, 04:45:09 AM »
They've got knurled edges Steve. Might be a bit hard to get off after awhile. Cheers, Terry. ;D
Offline UnCrash
  • Pass
    • My Blog
« Reply #13 on: April 07, 2008, 04:52:38 AM »
What if they looked like the 76 750K Oil Cap?
That would blend in nicely...
« Reply #14 on: April 07, 2008, 07:33:46 AM »
I can make several versions. I will work this week on the installation tool. They may be runnable by hand tightening but like you say getting them off will take more effort.
They will need a system to torque them a bit higher or  some will be afraid they will fall off. I will get more done on them this week.
Offline UnCrash
  • Pass
    • My Blog
« Reply #15 on: April 07, 2008, 07:50:59 AM »
What about a strap wrench?
The edge would need to be thick anough for the strap to grip, but at least there's a tool out there which may work off the shelf for little $
Offline cbass*gxc
    • My Pics Page
« Reply #16 on: April 07, 2008, 07:55:16 AM »
I would love a set of round ones or maybe 2 sets.  I would love to see some different versions.
On another note you said you could make a tach cover to match?  Do you have any tach covers now that you would be willing to part with or would you be able to make me one?  I am not running a tach on my bike and need something to keep the oil from squirting out and the dirt from getting in.
« Reply #17 on: April 07, 2008, 08:03:35 AM »
It pretty well has to be a form of strap wrench, but I will make it small enough to fit in a tool pouch & not torque them overly tight.
I will make tach plugs as well.
I have not worked pricing out, but it will probably be (not written in stone) around 100 per set of 8 with the wrench.
« Last Edit: April 07, 2008, 08:06:54 AM by 754 »
Offline mystic_1
  • 1970 CB750K
« Reply #18 on: April 07, 2008, 09:49:10 AM »
For tightening, how about putting a small shallow hole in the surface with the knurling, then your tool would be similar to a shock adjusting wrench, just a flat curved tool with a pin to match the hole.
mystic_1
« Reply #19 on: April 07, 2008, 10:41:44 AM »
I had thought of that way back, but I want the cleaner consistent look. With that setup the holes would end up all over, not in line and part would have to be bigger diameter or taller.
Offline kghost
« Reply #20 on: April 07, 2008, 10:44:29 AM »
How about a small hole all the way thru?
Stranger in a strange land
« Reply #21 on: April 07, 2008, 11:01:02 AM »
Small hole thru would be about where the tip or point was.. I really want a low profile but may make others.
 I considered thru hole  (or 2) which  looks nice intersecting a radius, and only takes a bar or drill bit to tighten. ( John Reed did a series of covers like that on a H-D while working for CCI).
 I used to make a 2 color point cover for HD.. could maybe work that into these.. like a copper or brass insert in the middle.
bbl 2nite.....
Offline mystic_1
  • 1970 CB750K
« Reply #22 on: April 07, 2008, 01:10:54 PM »
I think that you'd run into the same problem with a through hole as you would with the idea I mentioned above, the holes would end up in differing alignments once installed.
The more I look at these, the more I start to thing that their simplicity is part of their appeal.  Extra holes would just work against that.  With a knurled edge like that, final tightening could be done with channel locks, a small strap wrench, or whatever.
Question, it looks to me like these have a radius leading up to the point rather than just a straight taper.  Is this correct?  More pics would be cool.
Thanks!
mystic_1
« Reply #23 on: April 08, 2008, 10:01:14 AM »
Yes it is a radius, I had built a few other parts where that would be a straight line..like a maching at an angle cut. The radius usually has a nicer look.
 As far as a hole or groove to tighten, I would rather have the clean seamless look. I ordered more material, will start soon.
Offline tank410
« Reply #24 on: June 09, 2008, 10:18:45 AM »
sweet.....I would love a set of round one too.
CB500
