One big problem is suggesting turning the engine over using the ignition points cam. This is a VERY BAD IDEA! The large nut looks like it's strong but it is not, the advancer assembly is fairly delicate and if you break it off you are thourougly screwed. It's more work and a bit of a pain but remove the alternator and turn the engine with the rotor attachment bolt. This baby is plenty strong enough.
One big problem is suggesting turning the engine over using the ignition points cam. This is a VERY BAD IDEA! The large nut looks like it's strong but it is not, the advancer assembly is fairly delicate and if you break it off....
Well, I can tell no one has taken that apart or broken one.Its not a nut. Its a nut shape on a spline. That "nut" is held on two tabs by the nut inside of it.Actually the "nut" is what your supposed to use to make small ajustments to engine position.
