thanks twotired, im working on the smurf....
...while listening to blues music in a helium infused atmosphere?
![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
question: what if I dont have a tap? and what if ive never tapped anything before?
Do you have money for another carb body?
Do you care that people will point and laugh? (what am I saying? You bought the smurf.
![Embarrassed :-[](http://forums.sohc4.net/Smileys/default/embarrassed.gif)
) Then see if there is room to put a nut on a longer screw through the body, and glue some rhinestones to it. Or, investigate dry wall screws.
![Sad :(](http://forums.sohc4.net/Smileys/default/sad.gif)
Or, buy a tap and learn.
![Cool 8)](http://forums.sohc4.net/Smileys/default/cool.gif)
Another question: The slow jet (the ones clogged) are different. 1 and 2 have what I guess are normal ones: number 3 has a weird pattern of holes, that are angled and circle the jet. Is this normal?
I don't think so. The carbs are all supposed to behave the same way. How can they do that with different parts in them? Check the numbers stamped on the carb bodies. Maybe you have a set made from different models?
TwoTired, you answer so many of my questions i should just have a red phone with a direct link to the TwoTired cave - thanks, i appreciate your time. no, im not going to ask you out to dinner. ![Tongue :P](http://forums.sohc4.net/Smileys/default/tongue.gif)
Dang, and I was getting pretty hungry, too. Dinner would be fine. Just don't think you can have your way with me!
![Lips sealed :-X](http://forums.sohc4.net/Smileys/default/lipsrsealed.gif)
