Author Topic: spark plug trouble  (Read 1262 times)
mk0094@hotmail.com
spark plug trouble
« on: August 13, 2005, 01:33:55 PM »
i need some help..... .i bought a new head, annd a spark plug seems to be stuck, but not the whole plug, just the threaded portion with the tip, is there any way to get it out?  or is there a trick or somthing'? the inside of the plug is gone, just the threaded part is left, and seems to be in trer pretty good
any help is greatly appreciated
thanks
mike
77F2cb
Re: spark plug trouble
« Reply #1 on: August 13, 2005, 02:36:29 PM »
If the head is loose (not on engine) try warming or heating it to 120-150 degrees.  The aluminum will expand quicker and more redily than the steel of the sparkplug.
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
« Reply #2 on: August 13, 2005, 02:46:55 PM »
spray it with PB Blaster heat it up some, and spray it again, let it cool down.  Put your socket in the freezer, heat head it up ,spray it angin and put your cold socket on and use a 3/8 impact if you have one.  If that don't bring it out,  the threads are had, so just muscle it out and fix the threads.
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
bike54
« Reply #3 on: August 13, 2005, 02:54:16 PM »
hi
ther is a engenering way you need a firm with a spark eroding machine they will erode all the steel away without touching the aluminium but it can get pricy to have it done, or get a special drill that cuts going anti clockwise they work normally get about half way in and the whole lot unscrews if you get a set of them start with the smallest and go up in sizes that way more chances off it givving up and comming out if not its a helicoil repair to the thread
bike54
ps use a bench drill
Offline frostypuck
« Reply #4 on: August 13, 2005, 05:36:14 PM »
Are you sure it's not actually a heli-coil that's in there? Or are you confident it is the spark plug.
Chris in Boston
Boston, MA, USA
