I just got done cleaning my carbs, 069a's, for my 550 about a week and a half ago. I first couple through a can of Berryman's carb dip ($19.99 at Autozone) and the other two in Simple Green. I had to run the first two through a total of 3 times to get spotless, kept them in there for times varying from 30 min to 2 hours.
With the two I put in Simple Green, everything was much faster/cleaner. Almost no dirt or grime to wipe off after I'd finished rinsing with water and blowing dry. They were so clean after 1 45 minute dip that they rainbow like finish on the aluminum had come back in full force.
Side note, all the carbs were equally dirty, temp in the garage was about the same. Bottom line: 20 bucks versus 7. This was a pretty large container, I want to say it was a comparable amount that's in the Berryman's gallon can. You don't get the handy little basket to dunk all your stuff in, but heck the Simple Green isn't even toxic. Don't give it to your dog though. And the wife can water down whatever you don't use for cleaning the house!
