Author Topic: 78' 550K stator  (Read 1029 times)
Offline prosolar
  • I've seen things that would make you shit out a book about puking
78' 550K stator
« on: April 15, 2008, 08:09:24 PM »
Hello, hopefully simple question:
I'm helping my friend Ryan (R550 here) fix his charging system on his 78' 550K.  I found that the rectifier is definitely bad, and I suggested a newer style voltage regulator but here's my question:  The stator resistance is 1.1 ohms and as far as I can tell it's supposed to be .35 ohms +/- 10%.  Should we even worry about that or is it possible the stator is also bad?  P.S. I checked the resistance all ways and it's always the same.
69' CB750
75' CB550K
78' CB550K
79' KZ650
82' GS1100G
04' Bandit 1200S
Many others
Re: 78' 550K stator
« Reply #1 on: April 15, 2008, 10:32:25 PM »
Anything is possible, but do remember to zero your meter for low readings AND in 30 yrs i NEVER seen a stator go electrically bad unless physically damaged!
Re: 78' 550K stator
« Reply #2 on: April 15, 2008, 11:12:48 PM »
What does your meter read when you simply touch the probe tips together?
Offline prosolar
Re: 78' 550K stator
« Reply #3 on: April 16, 2008, 09:30:26 AM »
Thanks for the replies.  I'm been at this long enough to know about checking the resistance of my meter, which is a high quality unit.  So the 1.1ohms is actual.  Additionally the field coil was right in spec.  I'm thinking of just running it but I thought I'd check with you guys... I have replaced a defective stator on a CX500 before, and that thing tested good but didn't charge.
69' CB750
75' CB550K
78' CB550K
79' KZ650
82' GS1100G
04' Bandit 1200S
Many others
