Author Topic: 400F UK left switch into US harness  (Read 1036 times)
Offline gregk
« on: May 26, 2008, 10:40:12 AM »
I'm trying to get a UK version of the horn/headlight control to work on a US bike.
I've been able to sort out the double filiment bulb issue on the front end and now signals, running light, brake light, headlight (high and low) all work. Even the headlight pass thing works. The horn however does not.  The wiring diagrams for the UK and US are different for the horn.  The horn does work when I hook it up directly to a battery and the switch is "new off e-bay".  It looks like the UK version grounds a black wire to the frame?  I thought the black is hot?  The light green goes to the horn.
The US version must ground into the wiring loom?
Anyone have any answers?
Greg
I don't want it to go like a motorcycle, I want it to go like a rocket!
Re: 400F UK left switch into US harness
« Reply #1 on: May 26, 2008, 10:56:54 PM »
Check wether the switch grounds the horn wire or connects it to a power wire as this will vary your wiring----both were used at different times
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #2 on: May 27, 2008, 01:19:41 AM »
I dealt with this EXACT problem when I wired my UK switch.  The UK wiring grounds to the frame, the US to the harness.
Go to the hardware store and buy a female bullet connector with the flat ring on the end.  Plug the end of the black wire into it, then unscrew one of the screws for the horn mount, stick the connector between the frame and mount, then tighten  it down, up against the frame.
Voila!  Horn is grounded and works.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #3 on: May 27, 2008, 06:51:07 AM »
That'll be a French Horn then GG?
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #4 on: May 27, 2008, 07:02:20 AM »
I was wondering why instead of beeping when I pressed the button, it played th first few bars of "La Marseillaise".
 ;D ;D ;D ;D
Offline gregk
« Reply #5 on: May 27, 2008, 02:11:35 PM »
GG
 If I understand this grounding thru the frame, then there is one terminal empty on the horn?  You say to run the black wire from the switch to the ground where the horn mounts to the bike.   The light green then  goes to either terminal?
Greg
« Reply #6 on: May 27, 2008, 02:58:55 PM »
NO, one version has one horn terminal fed with power and the other grounded by the switch
2nd has one horn terminal grounded and the other fed power from the switch
« Reply #7 on: May 28, 2008, 01:25:54 AM »
According to the diagram, the LG out of the horn switch plugs into a LG 2-into-1 plug on the harness.  The LG out of the horn itself plugs into the other female side.  The black wire coming out of the horn itself is grounded to the frame.
Offline gregk
« Reply #8 on: May 28, 2008, 04:20:38 PM »
GG
I grounded the horn to the frame like you said and took the LG wire to to the other terminal and everything works
Thanks
Greg
