Author Topic: Hydraulic Caliper for Honda CB200 Disc Brake?  (Read 5239 times)
erb4
« on: April 17, 2008, 01:46:42 PM »
Hey!
One of my buddies gave me a CB200 last night.  It's a bad ass little bike that spent its previous life as a dirt tracker.  Consequently, it has no front brake.  I'd like to install a brake for street use.  The original disc brake was operated by cable rather than hydraulics, which from what I've read doesn't stop all that well.  It would be no problem to dig up a stock rotor and install it.  If I do that, is there a hydraulic caliper that will bolt on?  I'm not opposed to a little fabrication, just thought I'd try the easy way first.
Thanks,
Ed
Re: Hydraulic Caliper for Honda CB200 Disc Brake?
« Reply #1 on: April 17, 2008, 10:20:45 PM »
Stock cable when in good order and adjusted right will work good enough to sqeal the tyre, having said that i expect parts aint easy to come by
erb4
« Reply #2 on: April 18, 2008, 01:28:55 PM »
Bryan,
I think I'm going to try the cable setup first before I abandon it... IF I can find the parts!
Ed
« Reply #3 on: April 18, 2008, 09:08:38 PM »
If you get stuck I will happilly try in uk for you. Used to be very common over here---even one nephew had one
erb4
« Reply #4 on: April 20, 2008, 07:53:06 AM »
Last night I tried mounting the caliper & bracket from my buddies CB550 on my CB200.  I won't admit why we had to take the caliper off his bike, but it *almost* fit on the CB200.  The two bolts on the caliper joint lined up perfectly, but the caliper pin was too long.  I'd like to have a look at the hardware from a CB350 or CB450.
Thanks for the offer to look for the parts.  I'm headed to the Oley, PA swap meet this Friday... I'm hoping to find an entire CB200 parts bike.
Ed
Offline mark
« Reply #5 on: April 20, 2008, 10:03:12 AM »
fwiw... 350 and 550 use the same caliper.
F you mark...... F you.
erb4
« Reply #6 on: April 21, 2008, 09:06:47 AM »
Thanks Mark.  That saves me some effort!  Looks like I'm sticking with the cable brake.
Offline Aaron J Williams
  • Old Biker
  • Member # 725
    • Dude's Garage
« Reply #7 on: April 21, 2008, 06:40:25 PM »
I just bought 2 cb200 parts bikes and both have the front brake system intact. PM me if you need any parts
There are old bikers and there are bold bikers but there are very few old, bold bikers.
Quote from: Gordon
Not doing what you can to make your bike ride-able during the best riding months of the year kind of defeats the purpose of owning it in the first place.
