Author Topic: 1974 CB750K4 Carburetor Years  (Read 1407 times)
computerpulse
« on: August 15, 2005, 03:36:28 PM »
What years do the carburetors from a 1974 CB750K4 Cross?  I just broke one and someone has a 1973
eldar
Re: 1974 CB750K4 Carburetor Years
« Reply #1 on: August 15, 2005, 03:46:41 PM »
I think carbs from 71 - 76 will fit the 74. They should be K carbs. I dont know if the F carbs ar different.
Offline Clyde
« Reply #2 on: August 15, 2005, 08:36:04 PM »
F1 (75/76) carbs are the same. The later 77/78 (F and K) are different
There are some jetting changes between the carbs mentioned, but if you transfer your original jets in, then no problem.
One point to watch out for is that Honda changed the fuel tap from the right hand side to the left hand side about 1974/1975. This was  done so that riders could turn the reserve on with their left hand and keep the throttle open.
This is worth  mentioning as at the same time the carbs had their idle adjusting screw transferred from the left hand side to the right hand side. Same carbs but would make it a little awkward to get to the idle if they do not match.
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline SohcCBs
  • 76 CB836F 77 GL1000
« Reply #3 on: August 15, 2005, 08:39:32 PM »
The carb bodies are the same thru '76, there were a couple jetting changes and the linkage changed somewhere in there.  I'm not sure when they went to unit linkage.
Offline Clyde
« Reply #4 on: August 15, 2005, 08:52:52 PM »
The unit linkage started at the K1 model. Any carbs from 71-76 (F or K) should be usable, with the provisos above
SOHC4 #1909
