Author Topic: Rear brake problem  (Read 715 times)
Offline ekim98
Rear brake problem
« on: April 24, 2008, 05:51:58 PM »
Ok, I put the cbr 1000rr pegs and gear shift and brake pedal on my 750k. The cbr brake pedal is approx. 5" long and the stock brake pedal was 9" long. Seems like I don't have a back brake any more. I've checked the brake shoes and there good, and I have made longer arms for the brake pedal and on the original pivot arm for the rear brake. I guess my extensions are not long enough to make up for the shorter brake pedal. Any suggestions other than going to a rear disc! I'm not wanting to buy all the disc brake parts if I don't have to.  :P
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
Offline kghost
Re: Rear brake problem
« Reply #1 on: April 24, 2008, 05:57:46 PM »
Its a combination of the two arms.
The brake pedal arm (The one that you step on)
And the part that actually moves the rod.
You could try lengthing the arm of the second. (the one that moves the Rod)
Stranger in a strange land
Offline Bodi
« Reply #2 on: April 24, 2008, 07:51:20 PM »
You've lost leverage with the shorter pedal. You can get more mechanical advantage by using a shorter arm on the pedal where the actuating rod attaches - ie locate the actuating rog closer to the pivot, or a longer arm on the brake cam lever - locate the actuating arm attachment farther from the pivot... or both. This may make the pedal travel too long though, it's pretty much trial and error and changing the attachment points isn't too easy.
If you've had the rear axle loose, try loosening it again and then tightening it while someone stands on the brake pedal. This centres the brake plate in the drum and can improve braking quite a bit if the thing has been tightened off centre. There isn't much play on the axle but I've seen a real difference doing this.
