Author Topic: continuing 1981 cb650 carb problems possible solved  (Read 2053 times)
redaccent
« on: April 25, 2008, 11:42:01 AM »
Well I have my 1981 cb650c running fine, but I still have a hesitation above 5000 rpms.   I checked the plugs and they were black, and I have a strong spark on all.   So this is telling me that I'm running rich.
Just for kicks I removed the air box cover and just bolted the air filter to keep it from falling off.
The bike ran much better.   I can go over 5000 rpms, and go up to 80 mph and above with no problems.
The only problems I have is cold morning starts, just have to warm up more.
The question I have is do I have to change the jets or the jets are dirty still.  The bike has headers on it, and the carbs are exchanged rebuild.
Thanks,
John
Offline Caferacernoc
Re: continuing 1981 cb650 carb problems possible solved
« Reply #1 on: April 25, 2008, 01:41:36 PM »
That's a common mod for 650's actually. If your plugs start showing a normal tan then your jets are fine.
Offline cb650
« Reply #2 on: April 25, 2008, 04:16:14 PM »
Did that to one last weekend.
spudw
« Reply #3 on: May 20, 2008, 09:51:34 PM »
i also have a 1981 cb650 and i had a hell of a time getting fuel into the bowls. it ran for a bit as long as i kept it above 3000 rpm. i have no air cleaner. a few minutes later it wouldnt start (a few sputters here n there but not enough to lay off the starter) so im wondering if the jets became clogged up again. i just cleaned the carbs out last week. should i clean them out again?
also i was wondering what the little knobs are on the bottom of each carb? they only turn one full turn until they hit a stop.
Offline 750goes
  • it will live
« Reply #4 on: May 20, 2008, 09:59:31 PM »
those little knobs will be the carb drain holes.
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #5 on: May 20, 2008, 11:05:21 PM »
The carb drain holes aren't knobs, they're more like nipples facing straight down from the float bowls.  And there's a screw on the bottom of the float bowl that you can loosen to allow the bowl to drain.
Spudw,
You sure the knobs aren't the idle circuit adjustors?  Are the knobs on each of the carbs, on the front underside just behind the manifolds?
The 1980+ model CB650s have EPA caps on the screws to prevent you from turning them too far out (to protect the environment, of course  ::))  Is it the flange on the front of the knob that's keeping it from turning, or can it make more than one rotation if you're loosening it?
CB750K4
Offline Hush
« Reply #6 on: May 21, 2008, 01:23:50 AM »
CB650 owner with also fuel problems, had read on a web site that these bikes run better without the airfilter cover, just replace the cover bolts with a couple of oversize washers and better breathing.
That's not my problem though, I have gas to my bowls and spark at the plugs but somewhere along the way the twain aint meeting!
Will watch your thread with interest.
Offline Jay B
« Reply #7 on: May 21, 2008, 05:23:02 AM »
Those are probably the idle adjusters. They have a tang on them that hits the float bowls to limit adjustment, thanks to the EPA. Next time you have the bowls off you can grind off the tang on the head of it allowing more adjustment.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline cb650
« Reply #8 on: May 21, 2008, 06:04:12 AM »
I ground the tab off the bowl.  The extra metal on the screw is nice to sometimes turn it by hand.
spudw
« Reply #9 on: May 30, 2008, 11:53:19 AM »
solved my issue... put more gas in fuel tank! lolz
now i just need to get carbs sync'd  :)
