Author Topic: loss of power(electricity)  (Read 1540 times)
Scorpion
« on: August 16, 2005, 12:56:53 PM »
1970 Cb750K, Chopper,was running then it started to , as I was riding to loose power, sounded like running out of gas (tank was full), Would wait about 5 to 10 Minutes then the bike would fire right up again, I could ride for a couple of miles then it would do it again, the engine would fade to nothing. I dont know much about cb750, but it doesn't seem to be the carbs (checked bowls, and fuel flow). Will GLADLY EXPLORE ANY SUGGESTIONS... Well almost any.. ;)
« Last Edit: August 26, 2005, 12:11:26 AM by Scorpion »
Offline dusterdude
Re: loss of power(electricity)
« Reply #1 on: August 16, 2005, 01:07:52 PM »
scorpion,did you check fuel flow when the bike was hot.you may have a stopped up vent in your gas cap and it is causing a vacuum in the tank.next time it dies open the cap and wait a minute or so and then try to start the bike and see what happens.as far as electrical goes i cant help you there too much.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
eldar
« Reply #2 on: August 16, 2005, 01:19:59 PM »
I would also think it would be a vent. I dont think electrics would do this.
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #3 on: August 16, 2005, 01:51:44 PM »
Never herd of it happening on a bike, but I had a mower that did that when hot.  I had to replace the coil, it would short out when hot.  But like the previous post, sounds like a vacum problem in the fuel flow.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
mk0094@hotmail.com
« Reply #4 on: August 16, 2005, 01:57:51 PM »
if you have an inline fule filter, check to see if it is clogged. also, if it is not a vacum problem, start at the pet cock and trace the fuel flow. see if it is just dripping out of the pet cock or if it flows, then check the lines and carbs, see if gas is getting to them. if the gas is flowing ok,  spray carb cleaner into the carb wher the fuel enters, and see if the re is a clog. then check float height.
Scorpion
« Reply #5 on: August 26, 2005, 12:10:21 AM »
Thanks for the feed back, sorry it takes me a while to respond, as I drive over the road, but anyaway. The filter is new, and the carbs are ok, continuous fuel flow noted. Have decided to move on to next phase, rebuild (entire bike) so as I make the mods to the Scorpion(name of bike when finished) I will keep all posted, pics soon. :)
Offline dusterdude
« Reply #6 on: August 26, 2005, 05:38:33 AM »
scorpion,i guess thats one way to skin the cat.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
