Author Topic: Pls. don't tell me the engine has to come out to replace valve cover gasket!  (Read 1227 times)
andmoon
I searched and it looks like the 750's require removal but nothing hit for 550s.
Offline cbass*gxc
    • My Pics Page
I didnt have to on my 78 550 but I do not know about yours.  I would say not but I will let some one else tell you for sure.
Offline Bob Wessner
  • "Carbs Suck!"
Sadly, yes, engine out for that on 750's.
Offline Bob Wessner
  • "Carbs Suck!"
Wait a minute, seems to me there are some posts about folks snaking a new one in there without removing the engine. Try a search. Not sure I'd try it, but removing an engine just for that does seem like a pain in the butt.
Offline Roach Carver
i am confused, are you working on a 550 or a 750?
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
I think you're asking about the 550, right?  If so, you should be able to perform a complete top-end rebuild with the engine in the frame should you so desire.  750s are a different story.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
jameseb444
Good question, how about a 350?
andmoon
74 550
jbswearingen
Oh, heck, you don't need to remove the engine for that.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Manual says it can be done in frame.
As for the 750, I read here somewhere that you can lift up the valve cover a wee bit, remove the old one and slide the new one in underneath
 Matt.
Gallery at:
74 550
The valve covers just unscrew to access the tappets.  8 of them.  Can be replaced when on the bike.
Th cam cover can also be replaced with the engine in frame.  But, if you don't put it back on right, you bend all the valves, and the engine won't run right anymore.
\Best look into getting a manual for the engine if you want to fix the it without creating a much bigger headache.
Offline cbass*gxc
    • My Pics Page
On my 550 I was able to take the whole top end including the cylinder head and cylinders, which was really nice considering I couldnt get one of the engine mount bolts out.  It made for a lot less weight to have to wiggle off that bolt.
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
twins, no. fours, not sure.
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
