Author Topic: Problem with 550  (Read 643 times)
deathtrapgarage
Problem with 550
« on: April 28, 2008, 08:57:57 PM »
I have a 75 cb550, when i start the bike and it runs, its runs real choppy, then starts to cut out and gas starts pouring out of the carb drain tubes? sometimes when giving it throttle the motor dies. could it be the floats are sticking? any info helps thanks again.
Offline Gordon
  • 750K1, 550K2
Re: Problem with 550
« Reply #1 on: April 28, 2008, 09:00:29 PM »
Very well could be.  Try tapping on the float bowls with the handle of a screwdriver to see if you can dislodge the stuck float/s.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: April 28, 2008, 09:06:28 PM »
Turn off the petcock and drain each float bowl into a clean, clear glass jar.  Is the fuel clean?  Any chunks in there?  Any water?  Is your gas tank clean?  Any holes in your fuel filter?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Chicago550
  • 75 CB550
    • Gallery
« Reply #3 on: April 29, 2008, 11:00:19 AM »
I had the same problem. In my case I had to readjust the floats and rebuild the carbs.
75 CB550
70 CB350 gone to new home
