I know the exhaust has a little leakage around a weld or 2 that I can seal up. Wasn't aware that the pin-hole leak would make that much or a diff.
If your exhaust gasses have fuel in them, as they might during decel, the introduction of air into the exhaust can add enough oxygen to light off the exhaust mixture. POP
Don't have a manometer but will pick one up if the local shop has one tomorrow prior to starting work on the girl.
Make sure you get the addapters for the four intake runner plugs, too.
So far, I've only run her withour anything on the intake. Was planning on putting stacks on and figured that made little difference. That not the case?
If the stacks have any filtration restriction, they add a bit "choke" as Terry said. Theoreticaly, the stacks also should smooth out the intake flow and reduce turbulent flow. (Isn't that why your putting them on?) As the turbulence pressure points can move around within the carb bore with different velocities, it can change fine tune fuel flow. So, fine tuning should be performed with the bike in road configuration.
With the bike supposedly running great when she was parked before I got her I didn't think the synch would be necessary.
Two things. One persons "running great" and another persons, can be different. Further, the carbs are mechanically slaved, but there can be mechanical wear or vibration drift with operation. Did you take out the slides during the cleaning procedure?
Thanks for asking me the simple questions that I should have known to answer myself
You can count on me for the simple questions.
